Mine went to the kosovans shortly after its puddle dunking in February.  One wash a year is more than enough.
Rangie
The Range Rover will have to be cleaned this week it's absolutely caked in mud after taking the dogs out over the farm over the last few days , it looks like it has tackled a real off road course.
cam.in.head
Quote from: TheBoy on 28 December 2025, 13:25:38
youre a braver man than me .!
Migv6 le Frog Fan
Quote from: cam.in.head on 28 December 2025, 15:18:51
youre a lazier man than me .!
Fixed.  :y ;D
Migv6 le Frog Fan
Went to change a number plate light bulb on the C1 today, as the MOT runs out soon.
Bulb was fine but there was a break in a wire somewhere in the loom. ended up lying under the back of the bloody thing unplugging sections and testing for continuity until a found it. Then ran a bypass wire and solved the problem.
Probably a Frenchman assembling the Japanese wiring loom had stretched it too tight at the factory.  ::)
It has just clocked over 170,000 coming back from Hampshire.
I also got around to disabling passive arming, a feature that had been pissing me off since the day I enabled it 2 or 3 years back, but I'd put off because my battery support unit needed the plugs changing.
Rangie
Took the RRS to the "illegals" for a well needed wash £15 well spent 👍
Migv6 le Frog Fan
Im at work today, so brought the Omega with me and gave it a good wash as it was bloody filthy.
Might get the Hoover out soon and vacuum the carpets too.  :)
I suppose I should wash mine this year....     ...at some point.
Migv6 le Frog Fan
I count it as exercise these days. Need a little nap afterwards.  ;D
I did go back out and vacuum the carpets, checked fluids and tyre pressures.
Quite tiring, so Im glad Im on overtime rate for this physical exertion.  :D
Well, if you feel you need more exercise, and are passing Brakkers....    ...but you'll have to wipe the snow off first.
I've got to go over to Liverpool for mother's funeral on the 15th, so it'll get its six monthly wash before then. I may to ferry people around, so I'd better scrape the mud of the floor as well.
Diesel till I die
YZ250
Quote from: STEMO on 02 January 2026, 11:30:50
Sorry to hear of her passing. Condolences to you and your family.
Sorry to hear that STEMO, and even more sad to happen this time of year.
Quote from: TheBoy on 02 January 2026, 13:13:24
Thanks, Jaime. She was 96 and has been ill for quite a while, so it was not unexpected.
Diesel till I die
