Thanks Steve and Andy. Been hunting around the house for 'funeral clothes'. Haven't needed to wear anything like that for years now, I'm always out with the dog. Got a decent coat and a shirt and tie. Plenty of shoes tucked away, but all of my trousers seem to have shrunk around the waist. Don't know how that happened  :-\
Diesel till I die
Migv6 le Frog Fan
I have the same thing with mine. I blame the wife putting them on too hot a wash.  :y ;D
Migv6 le Frog Fan
Sons Civic overheating again, with loss of heat from the vents, after being fine since I put a bottle of flushing stuff through it a couple of weeks ago.
Got what I can only describe as thick soap suds type of stuff at the top of the rad when engine is running.
So presumably thats either residue of the flushing agent or head gasket failure.
Ime though HGF would be a stream of bubbles rather than something that looks like the inside of a washing machine before it starts the rinse cycle.  ??? ??? ??? ??? ??? ???
This started not long after the cambelt & waterpump were changed. Could be dodgy waterpump, but can a mechanical waterpump work intermittently ?  :-\ :-\
Had thought of throwing a new Rad on it to eliminate blocked fins, cool spots and the like, but I dont like playing parts darts.
Maybe a sniff test to check for exhaust gas in coolant ?
Viral_Jim
Quote from: Migv6 le Frog Fan on 08 January 2026, 11:57:45
This. There are a few options that could cause it, best to eliminate the most expensive first  :y
If its got a plastic impeller that's started to break down you could have a bit of plastic fin inside the impeller chamber that gets in the way occasionally and stops the pump spinning. I had a similar issue with a clutch once where a piece of friction material had broken off and occasionally prevented the clutch from disengaging  ???.
If you can whip the water pump off easily, I'd do this second, if exhaust gasses have been ruled out.
Third guess (and it would be a guess) would be a coolant cap as it could give you similar symptoms as a partially blocked rad but is easier and cheaper to change  :y
Quote from: STEMO on 08 January 2026, 11:45:01
I have a single suit now, that's used for weddings, christenings, funerals and interviews.  Obviously, it gets lnext to no use for weddings and christenings now...
Bizarrely, over xmas, it appears all my clothes have grown, and even my belts are too big. WTF?
Viral_Jim
Quote from: TheBoy on 08 January 2026, 14:16:17
Oh I don't know about that - next generation coming through soon  :P
Migv6 le Frog Fan
Quote from: Viral_Jim on 08 January 2026, 13:19:04
Wtaer pump is less than a year old, although that doesnt rule out it being faulty.
Its a real ballache to remove/ refit. It runs off the cambelt, which is a pig of a job because of really tight access.
I might be prepared to have a go at that if it was summer weather anfd I had no timesacale for getting it running again.
If we go down that route, he will probably have to buy another cheap car and gorget about this one until some time in the summer when I have changed the waterpump on this one.
I think test for exhause gases with an ebay kit. I f thats ok try and blast water under a bit ( but not too much) pressure around the outside of the Rad, and change the coolant cap.
Maybe flush it again and make sure its well bled to rule out airlocks.
Aint doing any of it in this weather though.
Thanks for the advice.  :y
YZ250
Quote from: Migv6 le Frog Fan on 05 January 2026, 16:28:28
The number of times I went to pick up the phone and call him, as was my nightly routine for years, was ridiculous.
Even though I've lost both of my parents, I still have their landline and mobile phone numbers in my mobile. I can't bring myself to delete them.
Migv6 le Frog Fan
I can understand that. Dad,s been gone over 10 years but I can still remember his number off the top of my head.
Quote from: Migv6 le Frog Fan on 08 January 2026, 19:25:20
I don't know anyone's number, I use their name. If I lost my phone, I'd be knackered  :)
Diesel till I die
Migv6 le Frog Fan
Im not too bad at remembering numbers. Its everything else that I cant recall.
Especially anything that I promised swmbo that I would definitely remember.  ;D
Quote from: STEMO on 08 January 2026, 19:42:54
I rarely use the contacts list in the phone, I still dial them manually for most of my friends and family.  It's only those people I call rarely, and never remember their numbers that I dial from contacts
Quote from: TheBoy on 09 January 2026, 11:26:47
Very old man-ish
Diesel till I die
YZ250
#28333
I rarely use the contacts list in the phone, I still dial them manually for most of my friends and family ...........
My particular annoyance is Voice dialling. It's probably me at fault but it never calls who I want it to call.  ;D
In the car, I press the steering wheel button and it beeps, I say the command for telephone and it prompts me to speak the persons name. For example, I say 'Call Dad Mobile' and the display says 'Calling Beefeater Torquay'.   ::)  As it happens, I do have Beefeater Torquay in my phone as we've used it several times, but how does it confuse 'Call Dad' with 'Beefeater'.  :-\
I had to stop using voice dial as the Beefeater in Torquay were getting pissed off with me calling them and hanging up.  ;D ;D
ronnyd
Voice dialling is not so good if you have a speech impediment.  ;)
