Author Topic: So what have you done to your car today?  (Read 6912720 times)
0 Members and 26 Guests are viewing this topic.
    • E250 Est / Elroq
« Reply #28635 on: 30 April 2026, 12:06:15 »
Not mine, but I fitted a new plastic Coolant Flange Housing to a Vauxhall Corsa 1.4 petrol. The old one split right down the middle and spat the coolant contents everywhere, and left a massive trail of steam.  ::)  Not a bad little job, although access is tight down the side of the engine, so I opted to add an extra five minutes to the job by choosing to remove the battery and battery tray to improve access.
This is the second plastic housing to properly let go on two separate family members cars. The first plastic thermostat housing to let go killed the Qashqai engine (engine has since been replaced FOC by Nissan), and now the Corsa has let go for the second time (the first time being a pin prick hole). As the Corsa was close to home, it appears to have escaped any serious injury.
That was the main issue on my Project Corsa....Which breakdown services convinced SWMBO's mate was a head gasket failure so he bought a new car the next day!
A minor leak can run down the block and drip off the bell housing and the engine heat can evaporate
the evidence up higher, making it harder to spot with the bendy mirror and a torch. As you know, a pressure tester comes in handy in that scenario, enabling the system to be tested when cold. In our recent case, a pressure tester wasn’t required, as it had a ruddy great split down the side of it.  ;D :y
When I recovered it, I changed the also leaking thermostat on his drive...and stopped to top up coolant 7 times in about 10 miles on the way home!  no temp guage either so wait for warning light city, then pull over!
You’ve probably already found this menu since you bought it, but you can bring up the temp gauge and other information between the dials by pressing and holding the trip reset button.  :y  These engines seem to run naturally hot. I’ve run live data on this one from cold and the temp runs to around 107-109 before the stat opens and the fans kick in. It then drops to normal temperature. The book says 103.  :-\
Indeed I have, given there is a little trip computer, beggers beleif they didnt think to add temp as a view on there.
YZ250
  • Oxford/Bucks border
    • Black 3.2 Elite Estate
« Reply #28636 on: 30 April 2026, 12:10:31 »
Indeed, I agree.  :y
    • 530D M Sport, 330i Coupe
« Reply #28637 on: 01 May 2026, 15:30:35 »
Not mine, but drove a Rover SD1 for the first time.
All I can say is that I am glad my first car was a MK2 Granada...
That said it was nice/fun/interesting spend time in something that analogue  8)
I owned a Moonraker Blue 3.5 Vitesse TP for around five years. It seemed a big car back in the day but it’s not when compared to today’s offerings. It seemed a comfortable car back then and mine had the ten digit keyboard for average mpg, ETA etc., so looked quite smart at night for its time. What didn’t look so good was the display showing less than 12mpg when doing 135mph, and as mentioned, the steering was frightening light at that speed.  :o
It rusted at the same rate that it used fuel but the engine never let me down. My wife hated it the day I bought it and still hated it five years later when I sold it.  ::) ;D
Frightening how much TP Vitesse's sell for now.... Hindsight is a wonderful thing!
I think kicking around in a 3.5 Series one before I was old enough to legally drive on the road (no comment) and then a 3.5 Series two SE is probably part of the reason in later life after the company cars, I bought the Omega's, just that barge with a big engine feel and that's probably led onto why i have the F10 530D and E92 330i now!
« Reply #28638 on: 04 May 2026, 15:17:43 »
Two new rear tyres on the E92 and oil and filter on the V70 this weekend.
« Reply #28639 on: 04 May 2026, 23:46:04 »
Topped up the windscreen washer fluid.  :)
The windscreen washers on my BMW seem to be quite thirsty as I've never had to keep topping it up so much with any other car, and it doesn't appear to be leaking out either.  :-\  ::)
Viral_Jim
  • Telford
    • Too many, mostly broken
« Reply #28640 on: 05 May 2026, 10:39:56 »
Another puncture repair on the family fun bus, and filled it up with diesel. Not the most fun £150 I've ever spent.
Counting down the days before I can ditch the old girl in favour of a second milk float  :D. I'd like to get away without filling her up again, but I doubt that will be realistic.
« Reply #28641 on: 05 May 2026, 12:11:09 »
...... Not the most fun £150 I've ever spent.
that's a frightening amount of money to fill a vehicle!  :o
« Reply #28642 on: 05 May 2026, 12:17:56 »
In my youth we used a length of tube and a dark night to keep costs down. ::)
LC0112G
« Reply #28643 on: 05 May 2026, 14:25:25 »
Swapped the winters off and summers on. Expect snow and ice in the UK for the next few weeks.
Viral_Jim
  • Telford
« Reply #28644 on: 05 May 2026, 14:50:00 »
To be fair, it was £122 and some pence to fill it and £28 was the puncture repair. Still far too much for a 13yr old people carrier with a 2.0 diseasel engine. Glad I'm not looking to fill something with a properly big tank.  :o
These days all that would get you is a lung full of vapour, I can personally attest to this from trying to drain the yankee wagon a couple of weeks back.   >:(
« Last Edit: 05 May 2026, 14:52:49 by Viral_Jim »
« Reply #28645 on: 05 May 2026, 19:04:03 »
To be fair, it was £122 and some pence to fill it and £28 was the puncture repair. Still far too much for a 13yr old people carrier with a 2.0 diseasel engine. Glad I'm not looking to fill something with a properly big tank.  :o ......
I filled my 14 plate  ML at the pump the other week .... the max of £120 didn't completely fill it!  ;( ;( ;(
« Reply #28646 on: 06 May 2026, 08:08:10 »
The local Sainsburys claim its £120 when paying at pump - the only option, as its unmanned - but all my cards come up with a max of £99 when I insert them.
Maybe they know its me ;D
YZ250
« Reply #28647 on: 06 May 2026, 20:57:01 »
Two new rear tyres on the E92 ……….
As you probably know, it’s pot luck what tyres you get on a new BMW, it’s sadly not an option that you can tick. I had a couple that left the factory with Bridgestone Potenza’s on my M Sports and I always found them hard, skittish tyres. On damp roads, the slightest variation in tarmac levels on a curve with the power on could lead to the rear end twitching, something I didn’t experience with the Michelin PS’s. The E92 is a well balanced car though, so it was never too much of a drama.  :y
« Reply #28648 on: 07 May 2026, 15:20:38 »
Ran my i4 down to 8% the other day, popped up to north to collect some roof bars so I can put a bike on the roof. (in addition to the 4 on the tow bar rack)
Cost me £2.03 to "fill it" back up at home  :D
« Reply #28649 on: 07 May 2026, 15:22:14 »
Hankook Ventus shipped on the i4 from the factory, can't complain. Grip is great, but xdrive helps there.
Bit early to understand how well they wear down.
