Author Topic: So what have you done to your car today?  (Read 6913017 times)
0 Members and 13 Guests are viewing this topic.
v6man54deg              Geffd
  • Wirral Merseyside
  • V6 man
« Reply #3810 on: 30 November 2012, 18:19:57 »
Replaced the bush on the drivers door stay - to stop that crack noise :y and removed the mudflaps that kept hitting every ramp
V6 problems solved : Worked at the V6 Engine plant for 13 years on durability testing and warranty issues, this job included many trips to Russelsheim, Trollhattan, Michigan, Atlanta,keiserslaughtern.
« Reply #3811 on: 30 November 2012, 22:00:09 »
Drove it after 3 days sitting idle ::) Noticed a few things... in no particular order:
Really agile, goes exactly where you point it, frost or no frost. Sooo much nicer than the 800k Daf suet I've been driving :P
It really relishes that nice cold ice cold air albeit at the expense of fuel economy.
Heated seats are great, but why no steering wheel heater :-\ nearly put gloves on to drive home ::)
The coolant warning was on, checked it, only to find level ok, but a big white golf ball bobbing up and down in the header tank >:( guessing the level sensor has expired :-\
Might treat it to a quick hoover tomorrow, assuming it's not snowing ;D
« Reply #3812 on: 30 November 2012, 23:37:18 »
Pretty much the same here.. After about 2 months idle... Not the Omega though. ;) Damned right on the heated steering wheel. ;D
« Reply #3813 on: 01 December 2012, 10:07:57 »
If the flotat has come off, you want to get the little plastic washer/clip that holds it on before it goes around coolant system.
« Reply #3814 on: 01 December 2012, 11:05:27 »
Best do that now :-\
« Reply #3815 on: 01 December 2012, 11:25:02 »
If the washer in question is about 3/4" in diameter, it has been fished out intact, guess it wasn't glued on very well :-\
« Reply #3816 on: 01 December 2012, 11:52:01 »
Thats it, same plastic as the bottle itself.
I think its heat welded on. So nothing a soldering iron can't fix ::)
« Reply #3817 on: 01 December 2012, 11:52:22 »
or superglue, but don't allow it to get on the float itself.
« Reply #3818 on: 01 December 2012, 12:05:07 »
Shall add it to the list of associated jobs when the cambelt is due, along with a new radiator ::) will try and squeeze 18 months out of the one I got from uncle Albert :y
symes
  • oxford
    • R reg 940 volvo
« Reply #3819 on: 01 December 2012, 16:57:53 »
Today did neighbours 2.5 v6
Fitted thermostat and temp gauge sensor
and Reverse sensors :y :y
« Reply #3820 on: 01 December 2012, 18:34:54 »
Put £75 worth of petrol in it and paid £47 for it.That should last me 6 months or so. :)
Im really hoping for a dry and not too cold day before Thursday so I can change the Dispack & stat on the Omega and once again delve into the problem of the Cavalier vac pump oil leak.
« Reply #3821 on: 02 December 2012, 18:08:06 »
Picked up SP-32s (Steve's) old Omega, think i'll keep it ::)
« Reply #3822 on: 02 December 2012, 21:09:42 »
Had plans for today,and tomorrow,but you know what they say about plans. :'(
Spent the whole day at the hospital (nothing wrong with me personally) and will be back there again first thing in the morning.
Starting to agree with TB about shutting down the NHS altogether after todays events.
    • E250 Est / Elroq
« Reply #3823 on: 02 December 2012, 21:30:23 »
Treated mine to an oil & filter change
« Reply #3824 on: 02 December 2012, 21:37:34 »
Very best of luck tomorrow Albs.
