bootie
Topped up the coolant 1.5 ltrs? Checked again after a 150 mile run to Rosyth and back (from Letham, not Spain) and needed to add another ltr???   HBV? Couldn't see any visible leaks.
Jon
Quote from: bootie on 17 February 2013, 13:31:35
Jon
Good chance... Need to have a decent poke about with the heater settings varied
Not me but martin replaced the fuel filter , it was full with what can only described as shite  ;D
Thanks martin  :y
Jon
As LD has said, but basically, if it's coming from the back of the engine, then HBV is first choice, and from the front, most likely the radiator (usually the left hand end ime :y ).
bootie
Getting dark here now, plus it's bl**dy cold!
Hopefully will get chance tomorrow before heading back home Tuesday.
Oh yeah, now have #1 injector leaking as well! (Separate post)
Jon
IanF
My back is broken after a weekend of work, Oil and filter change on the Omega complete break fluid flush and polished the head lights to sort out the horrible yellow pitted surface, then a Oil and filter change on my wife's Zafira and then to top it off, Oil and filter change along with new pads front and rear, new disc's front and rear and a break fluid change on the Fiat Panda 100hp, now treating my self to some nice single malt which is going down a little to easy. Cheers to all you :y
jonny2112
Just gave it a wash, but I finally remembered to clean in and around the jacking point covers. They were filthy  :o
symes
cured leaking oil cooler banjo bolt and rocker cover ??? and while there fitted new O rings on injectors :y
doz
Picked up LSD. Fek'd about with the LPG for hours then gave up. Fitted air freshener one of them funny hangin trees, then realised tomorrow I'll will have to use FORD power for my trip to work.  ::) ::)
Opened bonnet , jeez cant get my hands into get sensor  >:( Closed bonnet  :(
Quote from: EMD on 18 February 2013, 15:56:48
Should have bought a bigger car :P
On my 2.2, fixed washer pipe bodge, now back to as it should. Cleaned and hoovered it and got all junk, snack wrappers and other rubbish from Austria trip. Going to give it some fresh oil tomorrow, still very clean after 3k though.
Quote from: ex taxi al on 18 February 2013, 17:41:28
Yep , still working on it .. :) :P
DaveA
#4423
     Cleaned and serviced/adjusted, handbrake and checked discs (yesterday). first day of decent weather for a while.  Gave it a good wash and brush up, looks nearly new ::) :y
Regards
    Dave
Selseybill
