Author Topic: So what have you done to your car today?  (Read 8495697 times)
0 Members and 42 Guests are viewing this topic.
Shackeng
  • Ramsbury
    • 3.2 Elite 2.0 TitX Mondeo
« Reply #6390 on: 17 November 2013, 11:14:10 »
Replaced this :'(
With this :) :)
I see now why you decided not to fit 2nd Hand!
« Reply #6391 on: 17 November 2013, 11:31:17 »
Where petrol is concerned, definitely not worth it Chris :y
Shackeng
  • Ramsbury
« Reply #6392 on: 17 November 2013, 12:35:27 »
Agreed, should I be checking mine? ???
« Reply #6394 on: 17 November 2013, 13:49:36 »
V6 valeted & new set of wiper blades fitted, used Halfords ones again ( set28)...
They are shite, I've had 2 pairs myself on both 2.2 and 3.2, fine for a month or two, but they are very loud, each time they change direction "CRACK"
Switched to Bosch ones, also on Halfrauds trade, they feel far superior in terms of build. Also super silent, time will tell but going by here, they last a lot longer. Not the crappy 3 months or so Halfrauds own stock did.
Still ok on price, think they were £11 on trade, compared to £19
only ever used GM ones. :y
Used to use them, but silly prices now even on trade :(
m0rmh
  • kendal
    • 2.6 elite
« Reply #6395 on: 17 November 2013, 15:19:45 »
Cleaned out the drain under the pollen filter, and tried to find TC fault,  just about to bin the power sounder, and then going to twydle my thumbs till the cam belt kit turns up, so guess what I'm going to be doing next weekend
2boxerdogs
« Reply #6396 on: 17 November 2013, 16:14:55 »
Just put the alloys back on the 2.6 after being refurbed , very pleased with the result ... 2.2 will be done next.
« Last Edit: 17 November 2013, 16:17:38 by Tilbo »
« Reply #6397 on: 17 November 2013, 16:28:36 »
Drained half a pint of oil from plug wells  :o Wondered why it was smoking  ;D New cam caskets fitted thanks to Martin  :y She sounds beautiful  :-* :-* :-*
MR MISTER
« Reply #6398 on: 17 November 2013, 18:02:23 »
Martin is a girlie??? :o
Mr.OmegaMan
  • Middle of nowhere
    • W205 C43
« Reply #6399 on: 17 November 2013, 18:12:31 »
Low Oil warning came on the display 60 miles from home, Did check the oil before setting off and it was one level below full and when I pulled over after the warning it had barely 2 levels, Checked around too see if it was leaking oil and there was not a drop anywhere or at home, By the way it doesn't smoke either, I topped it up by 1L at a garage just encase as I was a little worried, First time I've seen that warning pop up. Although it hasn't had a drop of oil since it was changed in June 2013 and a few thousand miles driven. Normal usage for a 190k car I presume  :-\
bigbadee
  • plymouth
  • sorry about the spelling
    • omega diesel 2003/2.2
« Reply #6400 on: 17 November 2013, 21:59:00 »
drove it to a wall :'( to be more accurate pulling out of my tight drive lost concentration and scraped the front arch along the wall ,needed a bit of work anyway so guess what ile be doing next weekend :(
« Reply #6401 on: 18 November 2013, 08:56:22 »
Wondered why the heater wasn't working .. noticed the outside temperature display now reads 'F ºC' - I'm sure it was working last night when I parked up  ::)
Another job on the really long list. The list that's rapidly becoming "The list of reasons I want to replace my damn car."
« Reply #6402 on: 18 November 2013, 14:11:59 »
Can drive it without eyes watering from smoking cam gaskets through the vents  :o
biggriffin
  • huntingdon, Hoof'land
    • It's Insignificant
« Reply #6403 on: 18 November 2013, 14:16:59 »
new outside temp sensor needed.
Hoof'land storeman.
Dan282
  • Stoke on trent
    • 2001 3.2 Elite
« Reply #6404 on: 18 November 2013, 21:03:38 »
Randomly decided to valet the mig today for no reason. Not even using it at the moment.  :-X
