Quote from: m0rmh on 23 November 2013, 16:09:26
Finally got to the problem of spanner light and TC light on all the time,  went round all wheel sensors cleaned all seemed ok,.  Lights still on !  Checked connections to main ecu looked ok,  then checked connections to abs ecu, sprayed with cleaner reffitted hey presto no lights car running fine everything works as it should  ;D 8) :y one happy chap and one happy car!
Nice result :y
biggriffin
Quote from: tunnie on 20 November 2013, 19:23:23
Quote from: ex taxi al on 20 November 2013, 18:59:39
Changed the plugs on Ds 3.2... 246 coilpack is a pita to get at with all the lpg paraphernalia, but got there in the end :y
Now idles smoother than a very smooth thing  8) Nice to meet you D :y
It's a 3.2, it cannot idle that smooth  ;D
mine ticks over smoothly since i fitted 3.0L downpipes,and put ngk plugs in.
Hoof'land storeman.
biggriffin
Removed back seat sqaub, found two Lego men, 15 yogurt raisins,and 32p, then hovered it all out and cleaned all the leather. :y
Hoof'land storeman.
Got a mahoosive 100amp battery for the 2.2 wheesel, not Vauxhall but Exide with a 3 year G/tee and only £56 which i'm going to fit today. If the car ever fails to start i'll just put it in gear and drive it home on the starter motor  ;D
Quote from: Tilbo on 15 November 2013, 22:26:51
Once again , THEY WERE PERFECT driven 32,000 miles with no problems , funny enough if it rains I turn them on!!  What  a stupid comment can't use them much .
Tilbo, did you find them noisy, esp when changing direction?
I'm after some new wipers, and struggling to know what to get (MV6, so dont need the shitty aero style). GM ones are getting pricy, and dont seem to last as well. Might try the Bosch supers that tunnie suggests. Currently using a year old set of Goodyears aero from Costco, but I really dont like aero wipers poor cleaning performance (though a requirement on cars with those stupid overactive rain sensors). At £7 I way try Hellfrauds own brand
Partially stripped and cleaned the rear seat, carpet, door card and had to bin the drivers seat back, as I would never be able to clean it properly >:(
About to have a look and see what state it's in in daylight, but will probably end up pulling the sill trim out and dismantling the door card to ensure the edges are clean :-\
At last , got to the root cause of no radio reception , broken wire to the aerial connection plug  >:(
blackviper90210
Stripped the passenger door and replaced the door solenoid. It now locks/unlocks as it should. Replaced drivers door mirror, fitted floor mats and fixed the plastic trim on back of the front passenger seat then topped the oil. Happy days :)
AKA - Mr Bracket
Unplugged coolant level sensor plug and shorted it with a paper clip to get rid of the annoying onscreen message. Checked fluids while I was in there.
Prepped an AMG alloy for painting and then realised, with much annoyance, that I forgot to bring the paint to work with me. ::)
zirk
Picked up MV6 Provdrive Spoiler in back garden, moved about a foot, slipped, fell backwards into Rose Bush and hit back of head against a tree. Left spoiler where it is and went back indoors.  >:(
jonny2112
Quote from: Albitz on 24 November 2013, 14:36:14
:-X
jonny2112
Quote from: zirk on 24 November 2013, 14:46:43
Oh oh ...... is the spoiler alright? Are you okay?
zirk
Quote from: jonny2112 on 24 November 2013, 15:00:28
Yea, only went to move the bloody thing because I tripped over it last weekend.  ::)
zirk
Quote from: ex taxi al on 24 November 2013, 15:08:15
Be a lesson there ;D
Yep, let sleeping Dogs Spoilers lie, actually think I must be concussed, just looked at it again through the window, its not a MV6 Spoiler its a MV6 Bumper.  :-\
