Going to do some cam cover gaskets today, similar plastic affair to the Omega but on my Jaaaaaag ::)
omegod
Quote from: Elite Pete on 25 October 2014, 08:52:50
Pattern gaskets or OE ;D ?
Hope you got the mig sorted ok?
Quote from: omegod on 25 October 2014, 08:54:10
OE and much more expensive than the Omega ones plus I've bought genuine plugs which are Iridium and 100000 mile change time, thought I would do them while i'm there ::)
The Omega is first to be sorted this morning. Thanks for the parts Jon :y
Delroy47
Since Windscreen replace trim has lifted at the corners, screen fitter has just refitted and sealed  :y
chrisgixer
Quote from: Delroy47 on 25 October 2014, 09:04:40
Who's car did I see with a similar problem lately? Can't remember. Pauls?
Needs sorting or the lip the screen sits on will rust, swell and then discolour and eventually crack the screen.
Olympia5776
Omega has been sorned for a year now but I am able to drive it up and down the 200 yard private road to the main road . I'd noticed the engine management light coming on and knew it was the cam sensor that I'd changed a couple of years ago fitting a non OE one. I got a genuine GM one this time and fitted and light has stayed off . Was waxoyling the BMW E24 I'm restoring so did the inner sills ,inner rear arches and any dark cavities that I could find underneath the Omega . Messy job but very satisfying.
BMW is all painted now and all external trim fitted , interior is being refitted . Replaced and refurbished all the windscreen and headlight washer system , 14 m of tubing , 8 NRV's and 6 tee pieces . What an overtly complex system just to apply water to windows and lights . Severe mission creep has attached itself to the resto though...... ::)
joff
Washed it and a good vac, off to look at another 3.2 later this afternoon :y
pauls
Quote from: chrisgixer on 25 October 2014, 10:40:07
yep that was mine. Bloody thing keeps lifting even after smacking it.
chrisgixer
Quote from: pauls on 25 October 2014, 16:54:44
Have you got windscreen cover, and hopefully a chipped windscreen?
pauls
pauls
Yes waiting for week off to get it booked in :y
Quote from: chrisgixer on 25 October 2014, 16:56:19
amba
Been busy with the soldering iron today .Fitted a fused spur from back of main fuse box,thanks to great advise from Al,and I now have a proper ignition feed to my Dab receiver.
Can now listen to Planet Rock without needing ignition turned on which on my job is quite usefull as ofetn have time to kill between jobs.
chrisgixer
Quote from: Kevin Wood on 25 October 2014, 17:17:57
That big? ;D
I hope your not suggesting anything untoward though Mr Wood. :o
