chrisgixer
And forgot to look at a front shock re raising ride height. :(
ted_one
New steering idler, put spacers on the rear and fitted new horns..then a quick check over for Saturday's trip up to Serek's to replace the autobox :y
Two MOT's, One on my 2.6 and the other on Mrs VXL's Alhambra.  ;D
Also booked MOT for the 3.2 in just under a month!  ::)
2boxerdogs
Pollen filter change on the 2.6, nice easy job, scuttle drain nice & clean as well..
Quote from: VXL V6 on 15 October 2014, 22:11:02
Such fun changing 8 wheels in the rain.  ::) ;D
You need a battery whizzy gun.  I've been frequently swapping wheels due to punctures, wear and failed tyres over the past month. The gun speeds it up no end.
4x4
Changed discs and pads all round on truck,was not easy due to some idiot not greasing up the slider bolts,every 1 was siezed and only 1 snapped,so now need new bolt and front caliper carrier  >:(
joff
New O/S/R wheel bearing and a set of new S/L shocks
chrisgixer
Quote from: chrisgixer on 19 October 2014, 01:05:24
Changed oil and filter. Finally ::)
Had they actually been done last time... :-\
chrisgixer
Quote from: Doesn't play well with others... on 19 October 2014, 01:57:58
Depends which schedule is being followed.
Every 5k. No.
Every 8k. Yes.... Ish.
Schedule as applicable. As they say ;D
...tried to find a knock/clonk from the drivers front corner. Can't find anything amiss. :-\
Tightened the steerung bix bolts a fraction and crossed fingers. Might be the spring cup catching the wheel arch liner. :-\
Quote from: chrisgixer on 19 October 2014, 02:31:11
Every 5k. No.
Thought you paid someone to change it last week :-\
As for the knock... is the lpg ecu still secure? Knocking against the self leveling gubbins perhaps :-\
chrisgixer
I was concerned, as the canister body moved. Then stopped, before the cap finally loosened.  Are the bodies pinned?
Needed some leverage did that. :(
Later ones seem to be :y
Spin on conversion next time... ::)
chrisgixer
Quote from: Doesn't play well with others... on 19 October 2014, 09:46:49
Peg on the canister into a hole in the block I guess.
