Author Topic: 5000K HID Fog Install DIY.  (Read 7968 times)
CateraMV6
  • Lake Orion MI, USA
  • 2001 CATERA SPORT
    • 2001 Cadillac Catera SPT
« on: 12 February 2008, 00:58:00 »
Here are some pictures of my new HID kit, that I just installed this past weekend, I am extremely happy with it and its probably the best 70$ that I have spent on the car so far...  The frontal lighting has improved dramatically and now the Fogs can actually be considered useful in most driving conditions.
The kit is a 5000K HID H3, kit from eBay. Paid $72.49 for the entire thing.
Here are a few pictures of the kit...
Install Location.
And finally Light output...
Fogs Only..
Initial Start up...
Warmed up...
And a good comparison picture of all the color options...
« Last Edit: 13 February 2008, 14:52:46 by CateraMV6 »
caolan_p
  • IRELAND
Re: 5000K HID Fog Install DIY.
« Reply #1 on: 12 February 2008, 01:09:30 »
good job, i got a £45 fine 3 weeks ago for the fog's being on  :(
Ian_D
  • York
« Reply #2 on: 12 February 2008, 03:34:20 »
Looks good  :y
I keep thinking about getting a set for the main beam. Only reason I dont, is what happens if I flash someone out etc? Dont think its good for HID bulbs is it? :-/
[size=12]
CateraMV6
  • 2001 CATERA SPORT
« Reply #3 on: 12 February 2008, 11:58:44 »
Looks good  :y
Thats one nice thing about our headlights, we use H7 for the Lows and also H7 for the High beams so you can easily throw in one of those H7 lets say 5K kits and have no problems, remember when you use the high beams, the low beam remains on... so it will be just fine.
I want to see if a possible BiXenon projector is available that would fit our housings but so far no one has any info as to which ones fit... Let us know if you upgrade it thou,  :y
« Reply #4 on: 12 February 2008, 13:48:45 »
Looks good  :y
I saw somebody fit an Audi lense setup to the Omega headlight which had the solenoid dip function to....
CateraMV6
  • 2001 CATERA SPORT
« Reply #5 on: 12 February 2008, 14:36:24 »
Well I would love to find out about it... I have been looking at the bixenon projectors but they come in all different shapes and sizes and I am not sure which one will fit...
gstylebaby
  • stockport
« Reply #6 on: 12 February 2008, 21:05:57 »
Keep us informed if you sort anything out with these mate i like the idea of these if you look in the gallery there is a guy as stated before that fitted some and has a small bit of footage on you tube do'esnt help much but could be worth you having a look.
Lee :y
Minispud
  • Banbury, Oxfordshire
  • Ride hard with Passion
« Reply #7 on: 17 February 2008, 11:46:48 »
Hey CateraMV6, where did you buy the kit from, I like the idea of HID fog lights  :y
D.A.R.N.A Cycles.   Ride with Passion in your Heart
zippo
  • manchester
« Reply #8 on: 19 February 2008, 01:00:06 »
i wouldnt mind a set up like that myself http://http://www.eautoworks.com/ iam not sure if ive done the link right but these look very similar to the ones that cateramv6 has fitted
« Last Edit: 19 February 2008, 03:04:03 by zippo »
Crazydad
  • Germany
    • 2.5 V6 facelift
« Reply #9 on: 19 February 2008, 18:01:24 »
http://www.eautoworks.com/ :y :y
zippo
  • manchester
« Reply #10 on: 19 February 2008, 18:14:35 »
cheers mate   icant help being thick i blame it on a misspent childhood
Paul M
  • Edinburgh
« Reply #11 on: 19 February 2008, 20:20:40 »
Quite right too... total PITA those things, you might as well drive with the full beams on cos they're even better for blinding people!
I think it's long overdue that having fog lights on when conditions are clear should be endorsable -- 3 points and 60 quid. The chavs seem to think it's a badge of honour, no doubt due to it being illegal :-/
On the B roads with no-one else around use them all you like, but switch them off as soon as another car appears. Driving with them on into oncoming traffic is totally inconsiderate IMO.
CateraMV6
  • 2001 CATERA SPORT
« Reply #12 on: 20 February 2008, 13:44:07 »
Well on this side of the pond its different the cities are well lit so you dont need Fogs on at all, most of the times you cant even see your own lights because its so bright out, and when you are on the highway, the lanes are split far appart or they have a cement wall between so most of the time you dont see the other lanes, and they cant see you, and so if you use them most of the time you are bothering the ones ahead of you and that is if they are aimed improperly, mine are lowered down and they bearly reach 30ft ahead of the car but they light up the sides like no other, and thats why I like em....
So far I havent had issues with people flashing lights at me for them being too bright but they sure can be seen from long ways away.
With the dual xenon set up I put so much light on the road that I often times find myself leading a column of cars behind me and no one ahead of me, especially in the dark places in the middle of nowhere, most of the drivers feel comfy driving behind me and using my lights to see ahead... LOL...  ;D ...  >:(sometimes its anoying...
zippo
  • manchester
« Reply #13 on: 20 February 2008, 15:11:15 »
can you tell me what your light set up is, and where you bought the units from thanks
        Darren
Paul M
  • Edinburgh
« Reply #14 on: 22 February 2008, 18:46:15 »
It's a poor substitute for decent headlights though, and you can see quite clearly from the photos you posted that there is a lot of scatter above the cut-off.
Over here HID headlights provide plenty enough light, with a good cut-off and automatic levelling to minimise glare. And they work quite well, you can see well and aren't blinded by oncoming lights. If I switch on the fog lights on my Omega it makes very little difference to the light on the road, but it certainly increases glare.
I expect one of the problems in the US/Canada is the DOT standards for lighting. Quite simply they are a joke -- the beam patterns are often shocking, there is much more glare from what I observed. That before you even consider things like there is no requirement for distinct rear indicators (many cars flash the brake light on one side instead), and no requirement for there to be indicators visible from the side of the car (which is a nightmare on the freeway when making lane changes). The DOT is about 40 years behind Europe when it comes to lighting standards :o
I still don't like the idea of having fog lights on when there is oncoming traffic, the glare borders on dangerous at times -- I've often had to squint because of it, which obviously doesn't help your chances of noticing something unexpected happening.
