My new ex cop!
Started by GmasterT, 27 October 2008, 10:10:31
GmasterT
Bought on Friday, took it to pod on Saturday :D
Tresvant
nice looking car, and looks like your having fun  8-)
Very good indeed, and a car being used as it should be!! :y :y :y ;)
woodsy_mv6
Thats what i'm talking about :y
Standard suspension I see ;D
Join the club :-[
From the moment I picked up your book until I laid it down, I was convulsed with laughter. Some day I intend reading it.
GmasterT
yeah, completely standard bar a welded diff :D
It got on pretty well, (I do teach on the pod days so have a fair amount of experience!) I have some lowering springs lined up for it apparantly, but wont go too mad as its my daily driver.
It did scare me by giving piston ring type smoke signals, but Its stopped now, so I am thinking old hot oil getting thrown up into the heads... topped up and cleared through ok. Although the check engine light came on on the way home and I dont know why... still on now  :-?
mv6copcar
Quoteyeah, completely standard bar a welded diff :D
so how does the car corner with a locked diff on the roads...?
Great car mate  :y
Looks great fun, nice car too :y
Phil B
Does your insurer know?  :-/
GmasterT
Handles ok once you have got going, it is noticable on slow roundabouts and corners and a bit of a pig when parking etc (have to turn off the TC as it confuses it  ::))
The insurer doesnt know, I have trade insurance anyway, so covers any modification and I have had no issue on previous 200sx's with the same mod on 'normal' insurance, nice soap box btw  :P
GazS14
What sort of money are you looking at for an ex-police car and what level of spec do they have?  I take it they don't come with all the radio gear!!  :D
How does the handling compare to your 200SX?
QuoteWhat sort of money are you looking at for an ex-police car and what level of spec do they have?  I take it they don't come with all the radio gear!!  :D
They have GLS trim, and your looking about anywhere from 600-1400 quid I would've said dependant on cond. age etc.
GmasterT
I got mine at a really good price from a friend. Out of the box I suppose the drift handling is more or less on par, although the omega has a lot more weight obviously! The 200 will always be a better bet for getting serious though, if only for the tuneabilty, price and range of extras that are out there, plus no random lights that flash up as they are less likey to throw a strop after a bit of stick lol
Still love my mega though, did some demo/passanger rides at flame and thunder as good as any of the skylines etc, could go 4 up in the wet, more money! lol  ;D  :y
davlad22
love it! Could scare a few chicks with that!  :P
doog
sorry if i sound like a total idiot but how do you actually do the sideways stuff ?
obviously you cant do it on the roads
I would be worried i ended up facing the wrong way.
can you give a quick run down on how its done  please. :y
Doug
me at kick boxing
GmasterT
Quotesorry if i sound like a total idiot but how do you actually do the sideways stuff ?
Doug
Be a pleasure :-)
In an ideal world a locking diff and some useable power is the best way, but there are other techneques you can use to get the car sideways.
The initial getting sideways is the easy bit and can be done by either:
Clutch kick - Going round a corner as normal (even slowly) and dipping the clutch, revving the engine and dumping the clutch to 'shock' the rear wheels into spinning and sending the back out. Side effects when learning are mainly understeer. This normally comes about when you have not given it enough power (or manfoot  ;) ) which just sends a surge of grip to the rear wheels making the car push the front wheels forward (against the direction you are pointing them) causing good old understeer. The other reason is (often instinctively) Applying too much lock into the initial turn in the first place causing a similar effect of just pushing the front wheels foward rather than sending the back end 'out'
Hand brake/Emergancy brake (or wand!) - Used if going faster generally, gradually start the turn into the corner, dip the clutch, rip up the wand, let the back come out, drop the wand and lift the clutch/give the power. Common faults, dodgy handbbrakes and not dipping the clutch!
Power over - More or less what it says on the tin, going round the corner as normal and gradually but quickly applying more gas untill the rear comes out. Again, if the set up/power (you need a fair amount vs. rear grip) is not right or too much lock is applied, this can just turn into push on over steer.
Once the back is out:
Clutch kick - you back off the power for a moment to point where you want the angle to be from the initial 'upset' then apply the power fairly sharpish (if turbo'd/under powered another clutch kick may be needed at this point to get back in the power band)
Hand brake - the back is already out and you should be in the power band anyway by the time you re-engage drive as you raise the revs before lifting the clutch after releasing the handbrake anyway
Power over - similar to clutch kick, but if you have got to that stage already then a back off/flutuation of the loud pedal is all you should need.
My lunch break is now over, next is steering which I will do when I can, hope this all helps (evryone?!)  :y
