Whats this then
Started by Owen, 21 July 2007, 10:15:12
Owen
Mate of mine just poped round and gave me this thing. Its from an MV6 but I am not sure what it is ::)
Come on then, someone enlighten me, and tell me what it is, and is it any use to me at all? ;)
Nickbat
I think it's an immobiliser unit.
Had one fail a couple of years back and it was a barsteward of a problem. Took two weeks to locate the fault.
Keep it, you never know. :y
DaveL
Quick guess thingy to do with engine thingy. ;D ;D ;D ;D
8-)
DaveL
Baron Von Spongebob
#3
Omega 2.5 litre V6 (X25XE)
94 on 2 Bosch Motronic 2.8
0 261 203 588
90 492 382
XEBM3588
Vauxhall/Opel Engine Management ECU`s
Thats all i found. Im sure someone will clarify in more detail.. :y
[move]Is the world ready for me..[/move]
Owen
So its worth hanging onto then. If mine cops out does anyone know it the unit is as easy as plug and play?
QuoteOmega 2.5 litre V6 (X25XE)
0 261 203 588
90 492 382
XEBM3588
It is the engine management ECU that fits in the black plastic box behind the battery :y
miggy
#6
0 261 203 588
90 492 382
XEBM3588
Ooh, get you sheepy
;D ;D
QuoteSo its worth hanging onto then. If mine cops out does anyone know it the unit is as easy as plug and play?
I dont think it will work on yours, I had a MTek chip and wanted to swap it from my 98 3.0 to my 99 3.0 but was told it would not work :'(
QuoteIf mine cops out does anyone know it the unit is as easy as plug and play?
TB will confirm but I think it's paired with the immobiliser and key transponders so unless you transplant all 3 from a working car it will need a Tech2 to pair everything up.
Nickbat
It was the size that got me. The photo made it appear much smaller than an ECU. Yep, it is an ECU not an immobiliser. What a muppet I am (again!!!)
QuoteIt was the size that got me. The photo made it appear much smaller than an ECU. Yep, it is an ECU not an immobiliser. What a muppet I am (again!!!)
They're very compact these days considering what's inside  :y
Nickbat
If I'd bothered to check before rushing in, I would also have spotted it has more pins than an immobiliser. Double muppet.  :-[ :-[
Owen
#12
Well if its no good on its own, another bit to chuck in the shed just in case  ;D
STMO123
Think it has to be paired with ABS ECU as well.
Crazydad
0 261 203 588
90 492 382
XEBM3588
All answers are next to perfect found this :http://www.opelmoscow.ru/opelecu-cod.htm
