Phone Pics of the Info Center...
Started by CateraMV6, 06 March 2011, 00:21:37
QuoteThis may explain it;
http://www.omegaowners.com/forum/YaBB.pl?num=1290553985
QuoteI guess I will start with the cluster that I got from a Canadian CATERA:
The clue is obviously in the Canadian bit. ;D ;D ;D
Thanks Z
Are they not MPH as well then? or have I missed something....... ::) ::) ::)
[/highlight]
Canadian as in 'French' Canadian so kph? :D
They started metrification in the early 70's at the behest of the Liberal government under the then Premier Pierre Trudeau.
In the subsequent years various imperial units fell as victims to the metric equivalent, the result of legislation.
In the early 80's Premier Brian Mulroney's Conservative government decided that this had gone far enough and introduced legislation to repeal the adoption of full metrification.
There remains a hybrid system in place to this day although in this case distance continues to be  measured in kilometres and fuel quantity in litters but there has been a move to reinstate the imperial system of measurement when the Ontario government introduced changes in 2005 that allowed both systems to be taught in the maths curriculum.
I remember being confused when driving somewhere that the distances were in miles but the limits in KPH or vice versa. It was either Canada or the ROI. Possibly both. :-/  ;D
sotmh
Now i've heard of spotters, but for miggies ;D ;D
x25dt
#17
Plenty of gauges, I wonder does it have board computer like the euro version?
QuotePlenty of gauges, I wonder does it have board computer like the euro version?
no, it doesn't, the gauges are in place of the computer  ;)
CateraMV6
Wow sorry guys I was unaware of all the comments being posted here...
Yes the cluster is the Canadian one, I wanted to have KPH as a part of the OPEL look I was converting to, and thats the closest I can come to the KPH without messing with the other stuff...
I was wondering if the European center cluster could fit my car but couldn't find enough info, then the Canadian one poped on ebay for 30$... so I grabbed it.
The two are really separate meaning the center one with the speedo, tach, temp, and gas gauges is one unit... then the side one with the oil and volt is in place by a separate harness so you can actually remove it and install a custom display if you like... simple as that but you will loose a few of the warning lights...
None the less I got used to driving around with the inner numbers reading the MPH instead of the KPH and I Have a gps that has a log of all speed limits in the area so it warns me if I am speeding.
THe best part is when someone peeks inside and spots the KPH, its an instant...  :o
And Im like...  ::)
And they are like...  >:( (I want one)
And Im like...  8-)
LOL Sorry for the  ^  I got a good laugh at all the expressions..
Quote....
And Im like...  ::)
And Im like...  8-)
;D ;D ;D ;D ;D ;D ;D ;D ;D ;D
