And So It Starts
Started by pedroMV6, 24 April 2010, 20:09:42
I agree with all  the previous comments about the Carlton :y :y  It looks absolutely stunning from what we can see 8-) 8-) 8-)
Forget about the Omega project; let's PLEASE see some pics of that beautiful Carlton to bring back fond memories!! :D :D :D ;) ;)
pedroMV6
QuoteCarlton pics here...........
http://s11.photobucket.com/albums/a196/Pedropix/THE%20LOUTS/
Thanks! :y :y :y :y :y
You have made a really tasty machine out of what obviously was a wreck :o :o.  Great, lovely, work! :-* :-* 8-) 8-) 8-) ;)
SnakePliskin
AWESOME
Loving it matey
If that Carlton is anything to go by your Miggy Project will be AWESOME
Love VX's always Have
pedroMV6
Wasn't really a wreck, just looked that way.........it used to be a 2 litre too!
SnakePliskin
I can only work that sort of magic on a Cavalier Turbo not an Omega
Hat off to you matey ;)
andy_driver
good project a bit of advice mate before cutting weld up a frame inside the omega weld it to the pillars doors and rear qauter panels as this will hold everything together and stay the same .before cutting it so it doesnt flex while its being cut  :)
koni adjustable shocks eibach 30mm progrssive rate springs goodridge braided brakeline kit ebc redstuff ceramic brake pads all round black diamond drilled dics at front k+n panel filter  steinmetz body kit
pedroMV6
Quotegood project a bit of advice mate before cutting weld up a frame inside the omega weld it to the pillars doors and rear qauter panels as this will hold everything together and stay the same .before cutting it so it doesnt flex while its being cut  :)
Yeah, got it covered thanks dude - cut up a few cars for motorsport, so learned by now!!! ;)
kcl
QuoteFound another couple of pics.....
General one
Showing the wiring for the Bose amp and subwoofer
Beige leather seats and doorcards on a facelift estate, I want them too  :'(
pedroMV6
General one
Most of the rear door cards will be going back in, but the rear seat parts won't! :y
sess
another top quality motor on its way ;)
pedroMV6
Quoteanother top quality motor on its way ;)
I hope so Lord Sessford!
Found out that when doing this sort of work for a road going vehicle, it has to be BIVA tested and approved, but mine should pass OK.
Been on to ACE and had this as a reply:
Hi Pete, you are allowed to modify cars to a certain extent before requiring any form of additional test ( DVLA 8 points system) .
Any substantial modifications to the chassis or monococque immediately take you outside of this ,clarification below.
http://www.the-ace.org.uk/Chassis-and-Monocoque-Modification.html
A production car 'simply' modified into a pick up leaves you in limbo due to the way the regulations work.
http://www.the-ace.org.uk/BIVA-Pickup-problems.html
You ARE able to use the BIVA system only if you do a photographic history
of further work to the vehicle, ie further engine / suspension swaps.
We hope this clarifies the situation but if you need more feel free to recontact us.
cheers
Kev Rooney (ACE Admin Team )
Rich p
well all i can say is good luck with this, look's like a lot of hard work to go yet, and will watch for updates..
2.2 on lpg and loving it
Zuffenhausen
Interesting project, look forward to updates.
pedroMV6
Last of the stripping today, just rear hatch to remove, weld the doors up and get busy with the cutting disc.
Pics of how I am hoping to have the sides of the cockpit when done.
