lots of problems,
Started by sax-p, 10 April 2011, 13:52:54
humbucker
aye and then there would be one less saxo on the road  ;D ;D ;D
http://www.irmschermv6.com | #irmscherMV6
PM with your requests.
sax-p
Check out my 04 omega project ;)
humbucker
#62
Quote"rubs car" :'(
...door falls off...  ;D
jordan681
Quote"rubs car" :'(
LMAO   ;D ;D ;D ;D ;D ;D ;D ;D ;D ;D
sax-p..   when are we gonna see some more pics from this project..??
Always looking for a bargin..  PM me if u have any uprated Miggy parts...
Keep it coming, I can't wait to see the end result..... :y :y :y
sax-p
Update from my dads new white iPhone 4;)
The exhaust has seen better days.
sax-p
Flying without wings >:(
Just some pics I just after taking
So, Dad does all the work while son farts about with his camera ? Sounds pretty typical. ::) ;D ;D
sax-p
Started to dismantle the rear brakes, but then couldnt find out how to take the hub off >:(
Clarkey
Special tools required for rear hub removal. You will destroy the bearing to do it. Special tools also needed to install new bearing & hub.
Class project. Looking forward to seeing end result.
James.
sax-p
How do we remove the rear springs. :-/  Thanks Trevor
jack under the diff...
remove abs sensor wires,
free brake lines
release shocks (top or bottom)
undo the bolts holding the diff
gently lower
springs almost fall out.
replace.
as as per maint guide
http://www.omegaowners.com/forum/YaBB.pl?num=1170939305
sax-p
Thanks so much jimbob,  It would have saved us some time if we asked here first.
Thanks again,
Trevor
