Wanted: 3.0L Cams and Set of hydraulic lifters
Started by sev, 06 May 2009, 13:29:44
sev
Hi All,
I'm after a set of 3.0L cams and a complete car set of hydraulic lifters for a 2.5 v6 1995 CDX vintage.
I thought I might as well  get a whole set, so that I can clean them and drop them all in thus keeping the downtime to a minimum and then I can clean out my old ones at leisure and replace as necesary.
Thanks in advance.
1995 2.5 V6 CDX Saloon
And a lower inlet manifold from a 3.0.....
sev
Thanks for the heads up mark, are the port sizes different? how does it differ from the 2.5's?
markey mark
platty
QuoteAnd a lower inlet manifold from a 3.0.....
Not wanting to sound dim, but how does replacing the cams warrant a different inlet manifold?
tmx
yes it does how can the cams best perform if they have the same ammount of air going in?
Fitting the lower 3.0 manifold has bigger holes in it so more air goes into the engine
amba
Whe n I changed my cams to 3.0 last year I didn,t replace the lower inlet manifold.
So am I looseing out on potential performance ?
If so I am on the look out for a lower manifold aswell,if another is available.
Pm with details .
thanks
MutantCav
sev
I'm being dim here, I can see the lower inlet manifold having the bigger port size to accomodate the 3.0L engine, but what about the port sizes on the actual heads?
Would the 3.0L not have bigger inlet ports than the 2.5, meaning that the 2.5 head would still be restricted?  :(
RobseyMV6
Have all parts here part from the cams  ::)
QuoteI'm being dim here, I can see the lower inlet manifold having the bigger port size to accomodate the 3.0L engine, but what about the port sizes on the actual heads?
Correct = porting would be needed to get any gains :y
