Wanted 2.5 TD Oil Pipes
Started by Pitchfork, 06 June 2009, 15:24:53
Pitchfork
That run from engine to Oil Cooler. There are 2 types, I need the earlier version for my 1996 GLS Estate. I have a diagram that I can send to check it's the correct version
unlucky alf
have they just split or have the metal bits rotted?, only ive got a local firm that can refurbish pipes so if youve got the details i can enquire for you, not sure if they would need yours as a pattern or not though but worth a try ;)
Pitchfork
The metal pipe has corroded where it passes through inside of panel between engine compartment & wing. I need to use the car so will have to risk it until I can get a replacement. Thanks anyway
Pitchfork
Cancel that request.
Got some & problem solved
semisheen
Mine had exactly the same problem ...the early pipes come from the oil filter and double back on themselves and are jointed just at the side of the oil filter the latter ones are 1 piece and are routed slightly difrent ...but still wear away the same ....i know your sorted now ....i just thought i would mention it  :-/
