Engine wanted V6 not 2.5
Started by Martin_1962, 05 June 2009, 20:54:40
Martin_1962
Something I can fit to a facelift
I may need one
Will need delivering
RobseyMV6
I have two 2.6 lumps and 2.5 here, can't really deliver as way to busy at the moment  :-[
Martin_1962
WTF is up with yours martin??!!
MutantCav
Good 3.0 here with only 83k and cambelt, tensioners, water pump, oil cooler, cam cover gaskets and exhaust manifold gaskets done 6k ago with new plugs and good leads and dispack :)
AndyVXR300
Got 2 3.0 engines here one with 93,000 fvsh and the other one has 118,000, cant deliver but you are welcome to come and collect
The 93,000 one pull's like a train :y
GastronomicKleptomaniac
How much needs swapping to fit a non-DBW engine to a DBW car - ie, 3.0 into a 2.6? Is it a case of pedals, ECU, and not a lot more.. or is it far more complex?
QuoteHow much needs swapping to fit a non-DBW engine to a DBW car - ie, 3.0 into a 2.6? Is it a case of pedals, ECU, and not a lot more.. or is it far more complex?
Swap the sensors and plenum over and change the cam covers.....thats about it
MutantCav
Wow didnt realise thats all that was required...sounds nice and easy :y
Martin_1962
Well I was lucky - the engine survived the cam jumping.
However I do have a leaking HG now :-[ :-[
I will sort that in a week or so.
Worst case will be 3.0 DBWed
Is it the 135 leaking Martin? Through the temporary re-use of gasket/bolts?
Where abouts is it leaking?
Martin_1962
QuoteIs it the 135 leaking Martin? Through the temporary re-use of gasket/bolts?
Into the waterway
Pretty sure reuse of bits
Got the gasket, bolts on the way.
Getting peed off with stripping it now, last car I had to remove heads from used to take 30 minutes from switch off to head off.
marty31
Hi Robsey i am new on here i notice you have a couple of 2.6 engines for sale, how much do you want for 1 of them?
I have bought my 3rd facelift Omega this week but this one has a major issue, when i turn the engine over by hand it completely locks up.
Thanks
RobseyMV6
QuoteHi Robsey i am new on here i notice you have a couple of 2.6 engines for sale, how much do you want for 1 of them?
Thanks
PM sent  :y
