Propshaft, and odds and sods
Started by JamesV6CDX, 02 August 2009, 11:43:19
Hi Guys
I need - from a manual V6 estate -
1 x Propshaft
And then - the "gear stick assembly" and all the gubbins to change gear, that sits in the car, above the gearbox... will need the entire trim for this bit, ideally from a Facelift.  :y
MutantCav
#1
Got a 98 manual estate here...can supply the gear stick section and the front prop section...did you need the back section of the prop too??
The Red Baron
got it but you aint avin it. thanks for your reply with the gearbox, not. >:(
Quotegot it but you aint avin it. thanks for your reply with the gearbox, not. >:(
Just because I expressed a potential interest in something, and asked a question, I didn't commit to a deal upon recieving details from you, and, neither did I say I would get back to you.
It's a free country - and I happened to get a gearbox attached to the engine I bought, hence yours wasn't required.
Ok - Maybe it would have been nice to drop you a PM had I remembered, but there is really no need for your "you aint having it" attitude.
Grow up and put your dummy back in!!
