Author Topic: Wanted - Air Hose  (Read 6906 times)
star_whites
  • Rotherham
Wanted - Air Hose
« on: 16 September 2009, 22:16:09 »
Ok I will try and describe this as good as I can.
Im after a replacment air hose that comes out of the black plastic section next to the radiator. It is mounted right in front of the air hose that comes from the ICV.
Its the one that bends straight away and dispears down the back of the radiator. Mine has gone really soft and now has a large split in the hose on the bend and is covered in electrical tape for the time being. Needed quite urgent as go to Scotland in just over  a week.
Agemo
  • Cleethorpes
  • Insignia
Re: Wanted - Air Hose
« Reply #1 on: 16 September 2009, 22:48:36 »
Not sure what pipe it is, I would be tempted to replace with whatever comes to hand, even copper brake pipe if the diameter is right.
star_whites
  • Rotherham
« Reply #2 on: 16 September 2009, 22:57:26 »
Brake pipe would be no good, and neither is the standard pipe you can pick up from the local car spares due to it having a 90 deg bend in it.
Id rather replace it like for like. Someone on here will have one its just a case of waiting until the right people are on  :y
HNO3GOH
  • Somerset
  • Play time.
« Reply #3 on: 16 September 2009, 23:06:03 »
I'm breaking an MV6 and as of yet not touched the engine so if you could let us have a pic of where it starts and ends i'm sure i could help :y
Pete Elite
  • Uxbridge, Middlesex
« Reply #4 on: 17 September 2009, 01:40:09 »
   Hi, I had this pipe go all soggy on mine, its a secondary air hose and the part # is 93170033, only cost me about £7 from a VX dealer and is # 5 in the picture below :).
           HTH,
                 Pete :y.
star_whites
  • Rotherham
« Reply #5 on: 17 September 2009, 08:10:43 »
Yep thats the pipe pete. Any idea what makes it go all soft like that??
Agemo
  • Cleethorpes
  • Insignia
« Reply #6 on: 17 September 2009, 11:57:50 »
Looks like brake pipe would be far too small anyway. Cheap enough to buy new.
« Last Edit: 17 September 2009, 11:58:15 by Agemo »
star_whites
  • Rotherham
« Reply #7 on: 17 September 2009, 12:26:34 »
All sorted, ordered from local VX dealer for £6.83 plus I get a healthy discount  :y
« Reply #8 on: 17 September 2009, 12:28:21 »
Might well be that the non-return valve is shot, allowing hot exhaust gases up into the hose.
If it were me I'd blank off the pipes from each exhaust manifold and ditch the whole system.
Pete Elite
« Reply #9 on: 17 September 2009, 14:13:49 »
  As Kevin says it probably is the non-return valve as this was replaced on mine when i was doing the cambelt change and tested it as Mark does on the DVD and found it was u/s so got one off of here but damage to the pipe was already done :(.
 Don't bother getting one from VXs as they are over £100 just for the valve so a decent s/h one is the best and cheapest route, 2.0L are the same so should be easily available on here :y.
star_whites
  • Rotherham
« Reply #10 on: 17 September 2009, 20:48:08 »
I replaced the egr valve two weeks ago if that is what your on about??
Pete Elite
« Reply #11 on: 17 September 2009, 21:43:35 »
  No not the EGR valve the Secondary air system non-return valve which is attached to the shiny pipe that runs along the front of the cable tray behind the bagpipes, # 14 in picture below :y.
   You should be able to blow into it but not suck, if you can suck then its nackered :(.
               HTH,
                      Pete :y.
star_whites
  • Rotherham
« Reply #12 on: 17 September 2009, 22:20:17 »
Ok, I know what you mean. Does anyone have one available?????
I also need to get hold of some of the rubber mounts that secure various items securly (items 16/17 plus others) hopefully will be able to stop things moving about then.
Also need a couple of the black blanks that cover the holes on top of the plenum. It annoys me everytime I lift the bonnet and see two missing  ::)
star_whites
  • Rotherham
« Reply #13 on: 18 September 2009, 17:09:54 »
Has anyone got any of these???  :-/
philhoward
  • Staffs
  • Love the engines, so put one in something else..
« Reply #14 on: 18 September 2009, 18:32:05 »
I'm sure i've got 2 of them - one off an old engine, plus one off the one i'm dismantling at the moment (a 2.0, but looks identical)
Running an X30XE in a Reliant Scimitar GTE as I can't have an Omega as a company car...
Page created in 0.008 seconds with 16 queries.
