Wanted - Ignition Lock Cylinder
Started by DJ Pete, 30 December 2009, 13:51:55
DJ Pete
I am trying to find an Ignition Lock Cylinder for my 1996 2.5TD
It is the bit shown in this photo :
The end of the shaft has disintegrated on mine and won't operate the switch.
Thanks in advance.
andyc
Choice of two so be carefull on which one you get. All models upto Chassis Number R1999999 are the same and then change from Chassis Number S1000001 onwards
If your car still has the same locks that it left the factory with then i can get you a new Ign Barrell, in one piece.
The early on is £30.78 + VAT and the later one is £38.70 + VAT
To order would need Reg Number, Chassis Number & owners name & address
Cheers
Andy
Thetford. Norfolk
DJ Pete
That sounds like a bloody marvelous idea!
I will PM you. Thanks Andy
