2-4-6 coil pack for y26se wanted
Started by joshwyatt, 02 January 2010, 19:08:07
Quotewhats the symptons Josh, tried new plugs first?
Yep - it's defo the coil pack  ;)
Coolio, missed the thread on diagnosis!  ::)
If it was your personal car i would say avoid second hand and buy new, but as this is a fixer-seller project, second hand will be fine  :y
joshwyatt
 ;D there was no thread...you're not losing your mind. James came round and did an excellent job on the cambelt change and service jobs. However there was a missfire, we swapped a coil pack on the 1-3-5 bank from another Omega and still the same, new plugs had just gone it...so hence it must be 2-4-6
Are you still planning on going to the scrappy at bloxham sometime? If so, let me know when and I'll join you  :y
Quote;D there was no thread...you're not losing your mind. James came round and did an excellent job on the cambelt change and service jobs. However there was a missfire, we swapped a coil pack on the 1-3-5 bank from another Omega and still the same, new plugs had just gone it...so hence it must be 2-4-6
Yeah think so, need to fix my washer jets first  >:(
