2-4-6 coil pack for y26se wanted
Started by joshwyatt, 02 January 2010, 19:08:07
joshwyatt
As title really, a known good one is wanted, also reffered to as dis pack I believe. For the 2-4-6 bank (N/S)
Paul D
Hi,
Are you after second hand coil pack.
joshwyatt
Either new or used...I don't mind. However, if used it must be known to be in good working condition
Paul D
I have done a rocker cover gasket change and bits, so have replaced both coil packs, they are working but do not have the rubber covers for the spark plugs
pedroMV6
Make sure it's the same part number - there are three different ones to pick from! ;)
QuoteMake sure it's the same part number - there are three different ones to pick from! ;)
What, for a DBW Y26?
Only one CPP pack that I know of?
I suspect you're thinking of the earlier DIS / non DBW engines?  :)
According to my EPC Y26SE only has 2 options ... and that's left or right .. :)
26  MODULE, IGNITION CONTROL UNIT FOR CYLINDER NOS. 1, 3, 5 (BOSCH 0221503026)    9118114
26  MODULE, IGNITION CONTROL UNIT FOR CYLINDER NOS. 2, 4, 6 (BOSCH 0221503027)    9118115
QuoteAccording to my EPC Y26SE only has 2 options ... and that's left or right .. :)
My understanding too - thanks for checking kind sir :y
Rockhampton
I can confirm - 9118115 as I've just got one for my Y26SE  :y
Previous GM Models include '00 Omega 2.5 CD Auto, '06 Holden Commodore Executive 3.6 Auto, '99 Astra 1.8 CDX Auto, several Astra Diesels.
You're Welcome young man .. :)
joshwyatt
Many thanks all!
Paul D, I'd like very much to take you up on your offer  :y
How much do you want for it?
whats the symptons Josh, tried new plugs first?
Quotewhats the symptons Josh, tried new plugs first?
Yep - it's defo the coil pack  ;)
pedroMV6
I had that messing about with the wife's Elite (2.5), and didn't know the later engines were different!
Aah well, every day's a school day! ;D
