2.5 Td est in metalic green breaking for spares
Started by tigers_gonads, 04 November 2009, 07:17:16
tigers_gonads
sadly due to been sold a sh*t engine for my v6 and that person refusing to even talk about it and being off the road for 7 weeks / in deep sh*t, i am being forced to sell / break this car to raise cash to fix the v6 ............... yes i'm on the dole and going bankrupt   >:( >:( >:( >:(
the car was taken off the road due to the following faults
power stearing motor output shaft leaking
wishbones
hand brake
a bit of welding
the engine has done 172, 000 miles and is in v good condition.   used every day and no starting problems ( hot or cold )  :y
oil changed at least 3 times a year  :y
the turbo is good as is the injector / pump system   ( good old diesel magic ):y :y
a few small things was sold earlier on in the year so it won't move under its own steam  :'( :'(
the back 5 window hav ebeen tastefully tinted  :y
i know what it is worth if i weigh it in so please lads and lasses .............. in the spirit of OOF .......... don't kick a man when he is down
cheers  steve
tigers_gonads
simonb
Might be after the rear door plastic strips and a couple of other things, a/c switch, ash tray and while im on would the diff be ok in a 2.0 petrol est?
Welung666
QuoteMight be after the rear door plastic strips and a couple of other things, a/c switch, ash tray and while im on would the diff be ok in a 2.0 petrol est?
No, diesels have a different ratio'd diff.
Agemo
I could do with a lift pump from the Diesel tank. Can't think of anything else at the mo. Have you got everything you need for the V6?    ::)
tigers_gonads
QuoteI could do with a lift pump from the Diesel tank. Can't think of anything else at the mo. Have you got everything you need for the V6?    ::)
pm sent  :y
Omega6pot
Working on my 30th Omega 3.2 V6 Special
tigers_gonads
steve2.5cd
Is the cruise control stalk available mate ?  ;)
tigers_gonads
elite estate
hi i need tailgate gas struts for an estate also load cover
i can collect pm me your no and adress
cheers
ash
tigers_gonads
MutantCav
Oh dear mate, where did you get the engine from?!?!
Blackie_No1
2000 Omega Elite 2.5 V6
