WANTED CRUISE CONTROL KIT FOR 2.0 16V AUTO
Started by Miggy24, 03 January 2010, 13:33:34
Miggy24
Hi does anyone have a cruise control kit for sale for a 2.0 auto
Have you already got a 4-pin brake switch in situ or do you need that as well?
Miggy24
Hi rob yeh i`ll need that brake pin switch too
Make sure you get the bracket for the throttle body, to take the cruise gubbins. They are not that common, as only 2.0 CDX would have had cruise  :y
So you want, throttle body bracket, actuator & cable, 4-pin brake switch + stalk.?
Miggy24
Exhaust manifold not removed yet but unsure of postage cost due to weight. You have a PM re; C/C :y
#7
QuoteHi does anyone have a cruise control kit for sale for a 2.0 auto
Have a look at the pics of the throttle body where throttle cable is. Next to it do you have a square hole to take the cruise cable. If not you`re gonna need my throttle body as the bracket is part of the actual body.
Three studs under expansion bottle where the actuator casing sits
