F/S criuse control kit
Started by serek, 08 February 2010, 20:33:33
serek
  manual or auto cars
-criuse control ECU ( motor)
-stalk
-break switch
-clutch switch
-control cable ( sort, long plenum, or 2.0 16v ) not inc bracket
50£+PP or make me  offer
gra11
hi mate would this work with a 2.5td saloon? If so I will have it off you.
If you ain't fast! Your (in a diesel)
Quotehi mate would this work with a 2.5td saloon? If so I will have it off you.
You don't need all that lot with your car. You have a fly-by-wire throttle so you only need the appropiate stalk with the cruise buttons (different from above  ;)) and your car connected to a Tech II diagnostic gizmo  :y  :y  :y
gra11
#3
that right its the bmw engine so i didnt think it was fly by wire???
p.s. sorry for spamming  :D
david_omega
not sure the td is fly by wire, i have one here will check.
Only on the facelift. Preface are plug and play
Quotenot sure the td is fly by wire, i have one here will check.
DBW :y
yup, prefacelift TD just wack the cruise stalk on job done! Facelifts need tech2 enable...
Dave Elite
Quoteyup, prefacelift TD just wack the cruise stalk on job done! Facelifts need tech2 enable...
I thought thats what RobG said :-?
gra11
Aw perfect I should have a stalk here from my old vectra, will clash that on and see if it works as its a pre-facelift  :D
QuoteAw perfect I should have a stalk here from my old vectra, will clash that on and see if it works as its a pre-facelift  :D
A TD stalk isn't the same as one from a petrol car ......  ;)
gra11
Aw no right whos got a td stalk? ha ha
QuoteAw no right whos got a td stalk? ha ha
Buy new from Vauxhall dealer, second hand ones are false economy, they tend to fail much more quickly.
Plus new ones feel much nicer to use
To clarify this a bit, **NO** Vauxhall Omega 2.5TD needs a Tech2 to enable cruise.
