WANTED: TID Display
Started by adamk, 23 April 2010, 12:23:32
adamk
I am looking for a Tid display for my 2002 GLS {yellow plug} GM 24438373 Cheers!
To clarify, this is a TID not a MID
and in the wrong section.  ::)
Andy Pont
Hi
What you like with a soldering iron?
I picked one up on ebay really cheap, off a vectra. I took a bit of a gamble knowing part number was different to mine, but it had the yellow plug. The circuit board was the same but the housing was different. It meant that there was 3 connections to de-solder and resolder after fitting in my housing. Its a bit of messing about but there seem to be loads of these about all on different part numbers so i assume options are greatly improved if you can 'widen your search'. Dont quote me on this, but i suspect as long as you get the 26pin yellow connector the board will work but casing wont fit. Anyone able to confirm or correct me on this?
charlie
I've an yellow plug one here,its off an 2.0 gls facelift id letters bj number on back of tid 24400696.If any good pm me .chhers charlie :y
