FS: Facelift headlight washer 'kit'
Started by TheBoy, 30 April 2010, 09:13:48
Washer bottle with both windscreen pump (saloon only) and headlight pump, and washer level sensor.
Facelift washer jets (in Champayne/gold, but should be possible to respray?)
Associated tubing
Washer relay
The loom should already be in place (check first!)
Looking for £20 + P&P, collection or OOF postal service prefered, as due to size, postage may be high.
bigmac
Is that a 709 pump jaime ? plus whats the part number on relay
QuoteIs that a 709 pump jaime ? plus whats the part number on relay
Hi res pic at http://theboy.omegaowners.com/oofpics/Golden_Nugget_Parts/HiRes/headlightwasherkit.JPG
not sure if that helps.  Will check relay part number later
The missing number you can't see on that hires pic is a 9, so last 3 digits is 709.
The car is a 2000 Omega, hope that helps you in your search for a pump :y
