Wanted prefacelift Drivers Door solenoid
Started by John Lewis, 02 June 2010, 14:52:12
John Lewis
After a drivers door solenoid if anyone has one.
And seriously long shot, but also could do with a prefacelift Z489 passenger side rear door (elite) with matching trim. Didn't think so.. ::)
I think TB has the door but the trim will be different ;)
John Lewis
I have trim, just a bit nervous removing it from a dinged door and refitting..
QuoteI have trim, just a bit nervous removing it from a dinged door and refitting..
Removing it from a damaged door should be easy, its only held on with trim tape so a bit of heat should make it easier ;)
david_omega
door solenoids are same on all them on the drivers door, i put a 1996 N into a 2003 estate couple months ago, did the job central locking now mint.
John Lewis
Cheers for the info Simon, never knew that, in that case I need one off a newer car than mine  :y
Will ask the rest in the main forum Pete cheers mate, might be getting you lunch one day soon if you're free ;-)
