Pre Facelift bits and bobs For Sale
Started by MV6Matt, 06 June 2010, 21:06:03
MV6Matt
Please see below list of stuff that is no longer required.
If you need pics or further details post or PM me.
1.Standard front grill and V-badge
2.Lower Headlight trim(L+R) with head lamp washer cut out in Metallic Blue
3. Screen wash reservoir neck and lid
4.L+R door mirrors (heated and electric in metallic black)
5.Lower inlet manifold divider (from Petrol 2.5 V6)
6.Front sill end caps (L+R)
7.2x drivers door handles (1x metallic black 1x metallic green)
8.Drivers Door glass + front Passenger door Glass
9.Set Carbon door trims
10. Set metallic black door trims
11. Drivers door electric window raising/lowering arm
12.Auto gear surround 1x walnut 1x matt black
13.Walnut climate dash surround (no ashtray)
14.Orange front wing side indicators (L+R) with bulbs
15.Drivers door external trim strip (used)
16.O/s Passenger door external trim strip (new) (unusually has chrome strip with plastic underneath not at the very bottom like the one above)
17.Set 4x Vaux wheel centre caps (from MV6 wheels)
18.Set 4 Vaux badged mud flaps (F+R)
19. Estate Boot lid badge (used)
20. Estate rear reflectors (L+R)
21. CCR 600 Radio (code supplied)
22. CDC2 Blaupunkt 6 CD changer (code supplied)
23. 2x CD cassettes (for above)
24. screw in aerial
25. Estate rear bumper towing eye cover
If anyone needs/wants/can make use of - let me know before it gets sent to the Bay of E
Cheers
Matthew  :) :)
(thanks Ian)
Agemo
unlucky mark mv6 wanted some headlight trims, someone else here wanted a jacking point cover.   ::)
MV6Matt
Quoteunlucky mark mv6 wanted some headlight trims, someone else here wanted a jacking point cover.   ::)
That's very kind of you - I shall bare this in mind and thanks for the heads up!
Cheers dude!
Matthew :y
(thanks Ian)
russ b
what do yu want for the wood trim gear surround and console and how much for the cd changer.
MV6Matt
(thanks Ian)
MV6Matt
Just seen the post.
Unlucky wants facelift stuff not Pre-facelift.
I'm selling a towing eye cover not a jacking point cover.
Thanks for the thought though.
Cheers
Matthew
(thanks Ian)
Hannah Judes Dad
Don't suppose by some stretch of the imagination that you have got a lead that connects the bose subwoofer to the rest of the wiring loom knocking about anywhere?
MV6Matt
Unfortunately not!
Thanks for asking though!
Cheers
Is the Irmscher grill in place yet?
Matthew
(thanks Ian)
Hannah Judes Dad
Sure is and looking much better than the original vx offering  :y
Sixstring
Umm.......even my ORIGINAL grille has "Irmscher" on it ?????
QuoteUmm.......even my ORIGINAL grille has "Irmscher" on it ?????
Minifacelift Elites had an Irmscher grille, the rear spoiler is Irmscher too.  :y
