Author Topic: Help 2.6  (Read 2057 times)
krupauk
Help 2.6
« on: 04 August 2007, 20:22:41 »
Hello,
I'm new, i have a Vectra 2.6 Sri and I’m having problems with oil loss it’s done about 70,000 ish miles looking to find out if there is a problem with these engines or am i just paranoid, it still pulls like a train just want to know if i have got a duffer or not Cheers Iain
Nickbat
Re: Help 2.6
« Reply #1 on: 04 August 2007, 20:27:53 »
Hello,
You'll have to be more specific, mate. Is it burning oil (blue smoke from exhaust), or physically leaking it? If it's the latter, which I suspect, you may well have goosed cam cover seals. Inspect the plug wells to see if they have oil in them.
krupauk
Re: Help 2.6
« Reply #2 on: 04 August 2007, 20:39:32 »
Thanks for the quick response, it's only on start up in the morning i get the bule smoke from the exhaust for a bit then it's fine.
Nickbat
Re: Help 2.6
« Reply #3 on: 04 August 2007, 20:45:49 »
Hmm, not sure about that. One of the experts will be along shortly to offer advice.  :y
Omegatoy
  • UK
Re: Help 2.6
« Reply #4 on: 04 August 2007, 20:50:22 »
valve stem oil seals are tired mate!!
Re: Help 2.6
« Reply #5 on: 04 August 2007, 20:50:25 »
how much oil is it loosing?
As for the blue smoke it could be oil leaking from the cam cover gaskets, onto the exhaust or cats.....
krupauk
Re: Help 2.6
« Reply #6 on: 04 August 2007, 20:56:43 »
Thanks m8  :y the car has been looked after well since i got it regular oil changes and serviced by a Vx (good m8) mechanic who knows what he is doing, just don't want the big bills if its something major.
krupauk
Re: Help 2.6
« Reply #7 on: 04 August 2007, 21:09:15 »
Sounds bad! Is this going to be costly to fix if it’s the stems that are on the way out, was thinking of getting a 3.0 lump put in or trading it in for a 3.2 veccy but still not sure if I like the shape of the C.
Re: Help 2.6
« Reply #8 on: 04 August 2007, 21:47:04 »
Blue smoke from exhaust on startup in the mornings will be knackered stem seals I'm afraid.  Thats a head-off job to replace them.
krupauk
Re: Help 2.6
« Reply #9 on: 04 August 2007, 22:11:18 »
Looks like i will be calling courtenay for a 3.0 or 3.2 soon then  Cheers :'( :y
Re: Help 2.6
« Reply #10 on: 05 August 2007, 04:54:11 »
This would cause smoke from engine bay area, but not blue smoke from tailpipe.
For blue smoke to be puffing from the exhaust, oil is getting into the bore somehow - as said - the likely cause is stem seals. I would say, on a 2.6 litre, it's worth doing the job. I'd personally change all the valves too and get the new ones lapped in nicely.
Before doing any other work, compression test the engine..
Auto Addict
  • North Birmingham
  • Back to Vx to keep TB happy
    • Astra K Elite ST
Re: Help 2.6
« Reply #11 on: 05 August 2007, 08:06:29 »
As this is not Omega specific, I'm moving it to the 'General Chat' area.
I like red cars
Page created in 0.025 seconds with 16 queries.
