[WANTED] NCDC 2015 + Nokia phone module.
Started by Dany, 19 July 2010, 23:16:30
Dany
Hi all!
As said, if anyone has an "useless" NCDC 2015 headunit and a Nokia phone module designed for the glovebox (with a part of loom and connector), cheap, I'm a buyer...
Thanks all!
In all honesty Telematics is useable but not a patch on a modern handset.
Look on ebay.de for one but be sure that it's worth spending the money on when a second hand Nokia 6310i and Nokia Cark91 will give you a far better solution for less money.
Also consider that while the Telematics is as far as I can tell a proper GSM 900Mhz spec 8W device it does not cover the other bandwidths (1800Mhz etc) that the service providers now often use to fill in certain cells of high useage or poor 900Mhz coverage. I think Kevin Wood may be able to confirm or deny this  ;)
Dany
ErrrRRRRfff.... I have not thought about all this...! I have just seen this on the manual and I found it interesting, also for the SMS support. Moreover, I have now a NCDC 2013 that not read the half of my music CD's, don't know why...
QuoteErrrRRRRfff.... I have not thought about all this...! I have just seen this on the manual and I found it interesting, also for the SMS support. Moreover, I have now a NCDC 2013 that not read the half of my music CD's, don't know why...
If they are not original CD's, that till be the reason why. )They dont like CDR's for too long - ruins the laser)
Dany
Now I know why... I only use CDr's lol
The Nokia unit is a high power device, not sure what, but I can hold a conversation in my road on vodafone, which I can't with a handheld phone.
Dany - do your homework about how pairing etc works on these, else you'll end up with a brick.  And don't use CDRs!
Dany
QuoteThe Nokia unit is a high power device, not sure what, but I can hold a conversation in my road on vodafone, which I can't with a handheld phone.
First I need the device! I have just found one on German Ebay for 40 Euros, end in 3hrs...
Then I need a part of loom and the 32pins connector (I have only the 18pins one behind my glovebox...) AND wiring diagrams to know how to connect all that! I don't have found a "how to" on OOF, but hope someone helps when I will have the module in hands...
Just a clarification, and maybe a silly question but... I know I need a new SIM card but can I conserve my actual phone number or need a new number only for the car? When someone will ring me, what happens?
Thank you all again  :y
The one you buy MUST be depaired.  If not, it is no good and cannot be used.
As to SIM, depends what your mobile provider can do, as that varies from telco to telco, but here in the UK, very few contracts allow 2 SIMs on one number.
Dany
It's this one...
http://cgi.befr.ebay.be/ws/eBayISAPI.dll?ViewItem&item=290453101220&ssPageName=ADME:B:WNA:BE:1123
Never seen 2 SIMs cards contracts for one number here in Belgium... But I will ask my provider!
So, when you receive a call, your car and your sell phone rings together? If it's the case, can you answer only with your sell phone and disable the car? (to have more intimity when you are not alone on the road, for example)  ;)
QuoteIt's this one...
I believe one has priority, so if that is on and in range, that is the one that rings. But that may vary by provider.
Does it say its depaired? If not, its not much use.
You will need to also tech2 your NCDC, the CD Changer ECU and the display as well.
Dany
Google translation:
"The unit has been professionally Unmarried with TECH 2 and can be fitted to another vehicle". So I believe yes ^^.
I know for Tech2 the NCDC and the CID but there is another ECU for the CD changer? The one on the headunit?
QuoteGoogle translation:
Sounds like its depaired :y
Yes, the NCDC and its (integrated) CD Changer are logically 2 seperate items
Dany
Wierd thing... I will ask my Opel dealer for that, but I suppose he knows his job! I have to install the module first, but I need wiring diagrams... Can you help me for that? Do you already done this job before?
markspark
Back to the sim cards dany what i do is have 2 numbers the car one and my handheld one and i just divert all calls off the handheld to the car when im out in the car
