Wanted: various parts
Started by VXL V6, 26 July 2010, 22:12:34
Looking for:-
A good Headlight level sensor from the front wishbone.
Facelift front ashtray / working mechanism.
Facelift rear ashtray.
Facelift Saloon GPS/GSM roof mount antenna with good gasket.
Parkpilot sensor(s) and possibly control unit.
12 Pin CID connector + length of loom or a CDC2 connector and loom.
Metal clip off radiator shroud that the side shroud panel clicks into.
Many Thanks  :y
nell77
nell77
#2
QuoteLooking for:-
Many Thanks  :y
Got the level sensor, aerial, only drivers rear ashtray,explain what the cid wiring is etc PM`d you my number im up till about 12 ish if you  want to ring me
Neil
Will call you tomorrow evening if that's OK, I've found an aerial so would be looking for the Level Sensor, ashtray and the CID plug is tucked up behind the clocks and centre airvents, only really found on late Elites too my knowledge, it's a 12 pin right angle plug with a loom wrapped in grey foam tape.  :y
nell77
Plugs into the optional colour screen, hence why on most Elites it's tucked up behind the centre airvent area.
nell77
got it  2 rows of 6 on a black multi plug that has one of those lock down mechanisms on
Quotegot it  2 rows of 6 on a black multi plug that has one of those lock down mechanisms on
Yes that's the one!
nell77
you will have to explain more in detail exactly what you want pal so i dont get it wrong but guess i have it all here then but only drivers side rear ashtray passengers sold
All sounds good Neil, just want that plug with a length of loom attached to it (just snip the cable as low down as you can!).
Rear ashtrays are the same as far as I know.
Cheers!
nell77
#10
Rear ashtrays are handed pal.
so is it just the bit of loom or do you still want front ashtray and level sensor. which ashtray is it you want?
what is the clip on the rad?
Ah ok, didn't realise the rears were handed on the facelift - only looking for the ashtray, not the surround if that clarifies what I mean.
Clip is tiny piece of U shaped metal that sits in the end of the centre radiator shroud, the side piece of shroud then locks into the centre piece by turning the plastic screw 90 degrees.
If you could PM me a price for the plug/loom, Headlight level sensor, front ashtray and clip i'll get back to you!
nell77
get me a pic or can someone else on the rad clip.
And you still have`nt said which ashtray it is you want ie drivers or passenger
Right, the ashtray is the passenger side (Nearside) rear one.
Don't worry about the clip i've found one in the garage.
Cheers
