WANTED!!! speedo clocks for a 2.2 dti omega
Started by PP Silver DTI, 30 July 2010, 12:18:09
PP Silver DTI
Need clocks with roughly 120,000 on the clock, cash waitin! Thanks.....
Are you wanting a speedo due to it not working/broken.
Others will confirm this, but there is a known fault with the ABS ECU (not sure if it is the same on all models) but when that has issues the speedo stops working.  Thought it might be worth a mention.  :y
PP Silver DTI
Yes the abs light is on. What you think i should do? Thanks
Personally I would be posting in the Onega help section and asking what it means the problem is.
What it means when the light is on.
What may not be working as a result.
Plus what the cure is.
PP Silver DTI
