Author Topic: Wing Mirror wanted (Pls Move)  (Read 5850 times)
Lampynoiseboy
  • SE Essex
  • pay no attention to the man behind the curtain
    • '51 3.2 Elite "Floozy"
« on: 02 July 2010, 23:35:42 »
Hi All
Need a nearside electric heated mirror for an 01 (X) mini FL 3.0 Elite saloon.
Complete rear housing, front plastic surround &, I suspect, the metal innards c/w motor/loom etc
Glass would also be handy, but not essential as that's the cheap bit!
Prefer black, but if not black, no problem.
Cheers
Trouble strikes in series of three's, but when working on the car, the next job after a series of three is not the fourth job -- it's the start of a brand new series of three
Lampynoiseboy
  • SE Essex
Re: Wing Mirror wanted (Pls Move)
« Reply #1 on: 02 July 2010, 23:47:33 »
Sorry, assume the wing mirror is different from the earlier models? It's been a while since I had one, but if not an old one will do
Anyine advise on this?
Ta muchly
Lampynoiseboy
  • SE Essex
« Reply #2 on: 03 July 2010, 22:56:56 »
Have pm'd pete, if no I'll come back to you
Cheers
Lampynoiseboy
  • SE Essex
« Reply #3 on: 03 July 2010, 23:51:34 »
Drat & Blast (or words to that effect) he's only got offside.
PM sent to you mate
sjc
  • Alloa, Scotland
    • Ultra-dull Audi TDi
« Reply #4 on: 04 July 2010, 20:37:43 »
I've got a pre-facelift one here in Polar Sea Blue if that's any good?
Agemo
  • Cleethorpes
  • Insignia
« Reply #5 on: 06 July 2010, 11:26:36 »
Looks like you are sorted, I know someone with a pair of Silver ones for sale if anyone needs them.
« Last Edit: 06 July 2010, 11:39:23 by Agemo »
Lampynoiseboy
  • SE Essex
« Reply #6 on: 07 July 2010, 09:02:25 »
Hi All
Many thanks, have a pair on the way courtesy of Broomies Mate  :y
Will shout if any issues
Track rod ends I've been advised can be bought for £16 new from Euro car parts, so think for that price I'll have new, thanks to Simon Omega 2
« Last Edit: 07 July 2010, 09:02:40 by Lampynoiseboy »
Lampynoiseboy
  • SE Essex
« Reply #7 on: 15 August 2010, 00:38:19 »
Ok, seller had some issues, not his fault, but still need the mirror as post title...... anyone?
Cheers
Welung666
« Reply #8 on: 15 August 2010, 05:47:23 »
I've got a pair here if still needed. :y
Lampynoiseboy
  • SE Essex
« Reply #9 on: 15 August 2010, 21:06:27 »
easy way to tell, where is the block of 4 window buttons & rear disable switch?
by gear stick= pfl
drivers door= mfl/fl
Welung666
« Reply #10 on: 15 August 2010, 21:27:06 »
by gear stick= pfl
Incorrect, PFL & MFL are either side of the gearstick, FL are in the door.
The ones I have are Z359 Jungle Green Mica :y
Lampynoiseboy
  • SE Essex
« Reply #11 on: 15 August 2010, 21:34:08 »
i was given to believe that a mini facelift was bodywork & interior, full was the same plus new size engines. i have a 3L with new style body & interior , and mine are on the door- hence mine being mfl
hotel21
  • The Kingdom of Fife
« Reply #12 on: 15 August 2010, 23:20:43 »
If the window buttons are on the door panel (and you have an opening panel on the door) then you have a facelift (door panel, at the least).
Gaffers
  • NE Hampshire/Surrey
    • Ford Ranger Wildtrak
« Reply #13 on: 16 August 2010, 13:38:16 »
I have 2 available here in silver from a Pre-facelift.  NS has some black marks after a run in with a lane marker on an autobahn but if you are going to respray then that wont be an issue for you.
30 quid delivered if interested  :y
« Reply #14 on: 16 August 2010, 14:12:25 »
Incorrect.
Prefacelift - up to 1997, ribbed headlights, solid head restraints, no stereo buttons on steering wheel, Older MID etc
Minifacelift - 1998 and 1999, projector (or HID) headlights, solid headrests, audio controls on wheel, newer MID etc
Facelift - 2000-2003, Facelifted body, new interior, window buttons on drivers door...
Page created in 0.018 seconds with 22 queries.
