o/s rear brake caliper wanted
Started by mantagte, 01 September 2010, 11:46:46
mantagte
wanted o/s rear brake caliper (drivers side)
with bleed nipple that unscrews
charlie
#1
got one here kev £10 inc of postage,but i will check to see if bleed nipple unscrews first :y :y THis is for a non vented disc
mantagte
charlie
mantagte
Quote....
A siezed bleed nipple is relatively easy to drill out, particularly if you have access to a pillar drill of sorts. The hole down the middle makes a decent pilot drill for the bigger drill. Nipple is M8 tapping drill for which is 6.8 mm (17/64")  :y  :y  :y
mantagte
bleed nipple is not my problem (yet)
the flat where the pads sit on has corroded away so there is nothing except the pins and pistons holding them :-[
Welung666
Got one here and the nipple is fine :y
