1999 engine bay parts.
Started by Brikhead, 05 October 2010, 11:41:23
Brikhead
All parts removed from a 1999 mini facelift 3.0 auto.
Air filter box, £5.
Multiram (bagpipes), £10.
Inlet tract (the plastic bit with 'Eco-Tec' on it), £7.50
Throttle body flaps (the bit the accelerator cable attaches to), £10.
Accelerator cable (with electrical connector), £5.
Injectors-blue, £5 each £20 the set.
Injector wiring loom, £10.
Lower inlet/divider, £10.
Dip stick and tube, £7.50.
E.G.R. and metal pipe/bracket, £10.
Engine wiring loom, £30.
Engine wiring loom conduits x4, £7.50 each.
Timing belt cover (plastic, slight damage), £7.50.
Timing belt back plate (metal), £7.50.
Rad cover end pieces, £5 each.
E.C.U./relay box and lid, £5.
Alternator (14v 120a), £20.
Starter motor, £20.
Power steering pump, £10.
Crank pulley, £10.
Oil cooler, £10.
H.B.V. £5.
Heater matrix 90379972, £10.
Coolant radiator with auto box cooler, £10.
Coolant reservoir/expansion bottle with sensor and cap, £5.
Brake servo/master cylinder, £10.
Prices stated are for parts collected, Pay-pal and postage available.
1. Cam covers, £20 each or £30 pair.
2. Dispack, Bosch oval plug in as new condition, covered under 5,000 miles, £40.
3. Idle control valve and tubing, £10.
4. Maf sensor and housing, £7.50
The above 4 items are already packaged ready for posting, take the lot for £70+postage
