I too want a CCR 2006
Started by 2woody, 10 October 2010, 22:52:56
2woody
dad1uk
best wishes
Simon.
2woody
no, sorry. that's a pre-facelift single-DIN stereo
The CD changers are very weak, be lucky to find one that works! Also you want the CDR 2006  :y
ahh it was CCR though it was CDR  :-/
Quoteahh it was CCR though it was CDR  :-/
CDR - CD + Radio
CCR - Cassette, CD + radio
CCRT - Casette, cd, radio, tel
Well I have a CCR2006 in my DTi Elite which, when I get more than five minutes, I will be replacing with an NCDC.
It's currently in BOSE mode and everything works, however the bezel is worn.
NB. The autochangers generally only fail if they've been used with copied media for which the laser focusing was never designed to cope with.
2woody
#8
QuoteWell I have a CCR2006 in my DTi Elite which, when I get more than five minutes, I will be replacing with an NCDC.
that's exactly what I want - BOSE mode and everything....!
could you write "woody's" across it for me please
Yep no problem.
Got to finish off the loom (and decide if I want to put the tails in for a telematics), fix the front bezel on the NCDC and get TB to do some de-pair, re-pair and config work....
I have fitted the GPS/GSM Antenna though  ;D
RobseyMV6
Hi Woody, hows the Ro going? Have one here if you passing again at some point? comes with codes £90  :y
GWO!
2woody
Holden fine - transmission out now, so I'll be able to use more than two gears again soon.
have rear suspension off to weld on the camber/toe control arm brackets on.
then there's only the brakes to do .....
I have just bought a car with one fitted, so it's currently under review.....
rikki_essex
I now have a cdr 2005 with the cage and a ccr2006  but i just depends on weather the ccr2006 works as it should if it does the cdr 2005 will be up for sale
regards Rik
