'99 3.0 auto Mv6 black (z200) saloon parts. Again.
Started by Brikhead, 08 November 2010, 00:38:52
Brikhead
Deduct 50% from the prices shown below.
All parts removed from a 1999 mini facelift black (z200) saloon.
Rear number plate light, £5.
Rear bumper, all mounts intact but someone has put a screw through the towing eye cover, I can only guess why because it seems to close fine without it. £15.
Boot handle with backing plate and lock but no key. £10.
Fuel cap (screw on), £5.
Glass (rear quarter windows, with trim), £7.50 each.
Glass, front doors, £10 each.
Door handles (exterior), with backplates. £10 each or £30 the set.
Aerial and mount with two co-axial type connectors (perished gasket), £5.
Sunroof complete assembly £30.
Jacking point sill covers, 2 rear 1 front. £5 each.
Wiper arm 90493824LH, £10.
Wiper motor and mechanism, £15.
Plastic trim from below headlights (holes for H/L wash, 1 broken clip on passenger side), £7.50 each.
Lock set. Ignition, drivers door and complete glovebox handle, no boot lock and only 1 key blade. £30.
Steering wheel, £30 (I may get around to fitting this in my Vectra).
Steering column adjuster knob, £2.50.
Airbags (front) £10 each.
Window motors and mechanisms, £10 each.
Door wiring looms x4 £7.50 each.
Auto gear selector (cabin/interior) £10.
Auto gear indicator and 'ice' buttons, £2.50 each.
Accelerator pedal, £5.
Heater vent, front centre dash complete assembly, £7.50.
Heater vent, front side dash, £2.50.
Heater vent, rear centre assembly with ashtray, £7.50.
Climate unit display/control panel, £10.00.
Sunvisors (illuminated, with clips.), £5 each.
Head rest mounting tubes x6, £2.50 each.
Grab handles x4, £2.50 each.
Interior light (front, smoked finish), £5.
Interior lights (rear, one slight damage to switch mount), £2.50 each.
Tweeters, from front doors with surrounds, £2.50 each.
Indicator stalk (no cruise), £5.
Wiper stalk (variable, with m.i.d. controls), £7.50.
Ignition switch, £5.
Mirror adjuster switch, £5.
Glove box light and switch, £2.50 each.
Door pin switches, double pole, £2.50 each.
Electric window switches, 2 front and 1 rear, £5 each.
Brake light switch, £2.50.
Alarm bonnet switch, £2.50.
Alarm interior sensors, £2.50 each.
Door locking solenoids x2 (rear doors), £5 each.
Locking control unit (09146063) with 1 two button fob, £10
Transmission control unit, £10.
Power sounder and alarm horn, £10.
Traffic master, with switch. £5.
Light control module (09135155), £5.
Brake light (high level/centre), £5.
Relays – various, from £2.50 each.
Cam sensor Bosch 0232103017, £7.50.
Temperature sensor – outside air 09152245, £2.50.
Dash switches, Eco, TC, heated seats x2, hazard, alarm, heated screen, re-circ and one blank, all scratched. £2.50 each.
Air filter box, £5.
Multiram (bagpipes), £10.
Inlet tract (the plastic bit with 'Eco-Tec' on it), £7.50
Throttle body flaps (the bit the accelerator cable attaches to), £10.
Accelerator cable (with electrical connector), £5.
Injectors-blue, £5 each £20 the set.
Injector wiring loom, £10.
Dip stick and tube, £7.50.
E.G.R. and metal pipe/bracket, £10.
Engine wiring loom, £30.
Engine wiring loom conduits x4, £7.50 each.
Timing belt back plate (metal), £7.50.
Rad cover end pieces, £5 each.
E.C.U./relay box and lid, £5.
Alternator (14v 120a), £20.
Starter motor, £20.
Power steering pump, £10.
Crank pulley, £10.
Oil cooler, £10.
H.B.V. £5.
Heater matrix 90379972, £10.
Coolant radiator with auto box cooler, £10.
Brake servo/master cylinder, £10.
Prices stated are for parts collected, Pay-pal and postage available.
Brikhead
Rear lights. Outers £10 each, inners (boot mounted) £7.50 each. £25 the set.
Side indicators - orange, £750 for the two.
Front grill (broken lower centre mount, unnoticeable once fitted) £7.50.
Windscreen washer jet x1, £2.50.
2woody
Brikhead
Quoteafter a pair of rear springs - any available ?
No Mate, sorry, one of the springs had snapped and the other went as scrap metal with the shell.
