Wanted m/f estate bits.
Started by gstylebaby, 25 November 2010, 21:48:42
gstylebaby
Hi all need a few bits for a mini face lift estate =
Front seat belt tensioner not sure which one has gone so price for both please....(Black please).
Front xenon level bracket...(keeps popping off)
Relay and fuse box top cover this one has tape holding it down.
Thanks fellas. :y :y
Brikhead
I still have the engine bay relay and fuse box with lid from my p-f/l saloon...
http://www.omegaowners.com/forum/YaBB.pl?num=1289176732.
The level sensor should be the same from either pre or face, you can have the bracket for a fiver.
Front seat belt tensioner... Is that the bit that the belt buckle clips into when you put your seat belt on, or the reel that the belt winds back onto?
gstylebaby
Hi mate its what the seat belt clips into. :y
Whats the postage mate also have you still got the rear arm mate cause i'm still after that as well.
If you like p.m where abouts in the west midlands you are mate i mite pick up cause i would have liked the rear inside bits i asked you about....Not sure the better half would want me to be messing about with this one to much.. ;D ;D as still have my other one that i'm playing with..That is when i get the chance. :y
