Lpg kit
Started by 924boy, 06 December 2010, 10:14:05
924boy
Lpg kit taken off a '99 mini f/l 2.0. Was in full working order before removal. Tank is full. The only problem is when being removed the plastic plug that goes into the back of the dash switch broke and came off (but all 4 spade connectors are intact) so whoever fits it will have to work out what order they go onto the switch. Looking for £400.
QuoteLpg kit taken off a '99 mini f/l 2.0. Was in full working order before removal. Tank is full. The only problem is when being removed the plastic plug that goes into the back of the dash switch broke and came off (but all 4 spade connectors are intact) so whoever fits it will have to work out what order they go onto the switch. Looking for £400.
Thats going to be difficult, they are heavy enough empty. Its also not a good idea moving them full.
Must also be a very neat job, I can't see any LPG injectors or Mixer system
924boy
Its already removed from the vehicle and is being stored safely, and yes it is heavy but transportation won't be an issue as long as its strapped down securely. It is a very neat install but all the parts are present, I will add a pic of it all as it is now it has been removed when I get the chance to take 1.
