Wanted heater matrix
Started by Gaffers, 12 December 2010, 20:55:53
Gaffers
I have the dreaded heater matrix leak  :'(
so I need a replacement sharpish for a 98 mini facelift.  Please only offer up if you can deliver this week or if you are local enough for me to pickup.
cheers  :y
Brikhead
Would the one from this car fit?
(Look 3 up from the bottom of the first post)
http://www.omegaowners.com/forum/YaBB.pl?num=1289176732
£15, delivered...
Go to http://www.buypartsby.co.uk/radiators-final.php?year=1997&Submit=Next&make=Vauxhall&model=Omega&sub=&eng=2.5000 and scroll down to heater -  Part Number : NIS72655
Cost : £14.82 + vat  new.  For that price not worth fitting used mate :y
Gaffers
QuoteGo to http://www.buypartsby.co.uk/radiators-final.php?year=1997&Submit=Next&make=Vauxhall&model=Omega&sub=&eng=2.5000 and scroll down to heater -  Part Number : NIS72655
Cheers dbug, good spot  :y
Thanks for the offer too Brik  :y
Varche
Guffer - as a temporary fix you can bypass the heater by pulling off both heater pipe connectors and inserting a piece of 15 mm copper pipe.
The car is then quite driveable BUT wear warm clothes as the cold soon numbs your very bones.
Gaffers
QuoteGuffer - as a temporary fix you can bypass the heater by pulling off both heater pipe connectors and inserting a piece of 15 mm copper pipe.
The heater has already stopped working very well, I suspect near total blockage.  When the revs go above 3k I can hear it spit out of the matrix.  If I switch the temp to low it stops the leak.  The heater has always been a bit suspect anyways as the previous owner decided to drive short distances with a blown oil cooler, cleaning it out was very difficult indeed  :(
Gaffers
They're out of stock  :'(
Gaffers
Thanks Brik, the matrix arrived today :y
Brikhead
No prob's!
I hope it sorts your problem...
Cheers,
Rich.
