Wanted Face lift mats
Started by markspark, 02 January 2011, 23:34:42
markspark
as above i looking for a set of Omega mats the ones with Omega embroidered on them the genuine vx ones
Cliffo B
Know the ones you mean,have a set that I have made last a good few years, if you can lay your hands on some that have heel damage on the drivers mat (wear holes) I will be happy to do a restore job on that mat as I have on mine. I've spent the most of my life in the carpet and flooring fitting job,and have family still in it,the trick is to insert a rubber panel in the mat to remove the damaged mat, and prevent a recurrance of hole damage,after all it's because of the lack of a wear buffer pad that causes premature end of life to these mat sets hope I've explained OK :y
markspark
that sounds good thanks for the offer i will see what the mats are like when i find some
humbucker
cliffo any chance you could email snaps of the repair job before and after over? my drivers one is looking a bit worse for wear whereas the others are mint so might be interested in a resto job if the price is right, let me know  :y
http://www.irmschermv6.com | #irmscherMV6
PM with your requests.
Cliffo B
Hello Humbucker,Sorry computerised pics I cannot do,tried many times, last time lost family photos,was a disaster,simply given up on them.This is what happened to mine, obviously the drivers mat wears out well before the rest, with hindsight,in a set should be at least 5 drivers mats when sold as a luxury item, ie with no wear buffer pad under the drivers heels. As already said my solution,as I understand they are no longer made with 'omega' embroidered on is to give the drivers mat a wear buffer pad in the area under the drivers heels,in the form of a preformed section removed from standard nice looking 100% rubber mats, this has worked very well,in your case Humbucker if the 2 wear points are now holes as were mine I'll be happy to do yours for the costs,which won't amount to much :y
markspark
Has anyone found me any yet im still looking
