Wanted, front disc back plates (guard).
Started by unlucky alf, 31 January 2011, 23:10:40
unlucky alf
As mine have almost rotted away im after the above, not sure what they call them but its the tin guard things behind the brake discs,,,,,cheers. :y
sjc
Not sure they're worth the hassle to replace... you have to either remove the hub bearing or cut a slot in the shield to get it past the stub axle.
According to EPC, part number are:
90235204 LH
90235205 RH
But they £22.50 each  [smiley=shocked.gif] (can't remember if that's with or without VAT).
unlucky alf
QuoteNot sure they're worth the hassle to replace... you have to either remove the hub bearing or cut a slot in the shield to get it past the stub axle.
90235204 LH
90235205 RH
Cheers for that, i would like to get them changed despite of the work involved just to try & protect the discs a bit ;)
