wanted headlight
Started by fiend61, 20 February 2011, 08:07:42
fiend61
hi
i require a minifacelift n/s passenger headlight, not bothered about state of lens or whether adjuster is broken aslong as it is cheap enough  ;)
thanks
MutantCav
I have a broken adjuster HID one here if you want it...
fiend61
is that normal projector ?   i really get confused with xenon, hid etc etc
fiend61
the part number on mine is gm 09 117 187 lh
so it needs to be same shape as that i know facelift ones are a different shape  :y
Brikhead
Quoteis that normal projector ?   i really get confused with xenon, hid etc etc
H.I.D. and xenon are different names for the same sort of bulb.
'normal projector' headlights use regular halogen bulbs
fiend61
so hid and xenon use the ballasts where as projector use halogen correct ?????? :y
Quoteso hid and xenon use the ballasts where as projector use halogen correct ?????? :y
Yep :y
fiend61
ok then -
wanted "projector headlight" n/s (passenger) for minifacelift, not bothered with state of lens or broken adjuster, basically just want the black plastic enclosure intact
thanks
MutantCav
Black plastic enclosure is the same for HID and projector lights...both the same shape, same fit, just the internals that are different...and a ballast pack bolted on to the bottom of the light which the projectors have the fittings for too anyway :y
fiend61
fiend61
