H/Light washer pump wanted
Started by RobG, 14 March 2011, 20:32:56
As title. Need it for a facelift but I assume they`re the same across the range :-/
MutantCav
If they are the same I have one here mate :y
QuoteIf they are the same I have one here mate :y
Can you post up the part number Chris and I`ll check mine :y
fiend61
got a question about this  ;)
do you get another pump if retro fitting headlight washers ?
its just that i have seen pumps with two outlets  :-/
could these be used in the original tank (replacing the single outlet pump)  to do windscreen and headlights?
Twin outlet is for estate I think. Pipe bore for H/L washers on the Mig is about twice the diameter of the screenwash pipe
fiend61
ahhh i see (said the blind man)
cheers rob  :y
Because of the amount of water the headlight washers use, the tanks a lot bigger as well (but still not big enough) ::)
Of course the superior Senator also had wipers on the headlamps, so didnt need gallons of water to blast a bit of dirt off. ;) :)
