Wanted: V6 Injector loom plugs
Started by TheBoy, 26 March 2011, 18:38:06
I need the injector loom plug from the engine loom side, with as long a piece of loom on as possible. The is the large connector that you have to undo when removing inlet manifold, but its the engine loom plug I need, not the plug on the inlet manifold.
Hope that makes sense?
I've got one here I removed for Kevin, I assume its for the LPG ;)
QuoteI've got one here I removed for Kevin, I assume its for the LPG ;)
Yup, correct.
Yup, correct.
I don't suppose Kevin will mind you having it, he wanted me to take it to a meet but i'm sure i'll have another one by then ;)
Yup, correct.
Yep, it was partly with Jaime's need in mind that I asked you to keep them, so feel free to give it to him. :y
I'll have another one by the end of the week  ;)
Arrived this morning EP, thankyou :y
No Problem ;) Is there a need for more?
QuoteNo Problem ;) Is there a need for more?
I suspect so, though won't know how successful this is until we do my Elite.  Might be worth, if possible, keeping some aside :y
What are you doing, finding a tidier way to do the injector wiring, without using the piggy backs?  :y
Yup
Ok, i'll take them off this one as well, is the bit of loom long enough?
Yup
I'll be watching with much interest, thanks TB  :y
