Wanted Electric Sunroof control box
Started by tomoco, 29 March 2011, 22:53:29
tomoco
Need a replacement sunroof control (the one with the switch on) and the famous black disc. Mine only works if you press the switch in and turn it.
Its a facelist 2002 salloon .
Thanks    Mark  :y
Brikhead
I have a sunroof motor. Usually I sell them complete with the trim panel and knob as an upgrade for the Vectra 'b' but haven't gotten around to listing these yet...
Yours for £25...
Quote...... Usually I sell them complete with the trim panel and knob as an upgrade for the Vectra 'b'  .....
off topic but .......  ::)
they're also a direct (mechanically) swap into a Senator to allow total closure.  :y :y
tomoco
Thanks guys. I think im getting myself confused as to what part i need. I need the black plastic box. Its the one that contains the circuit board and the black disc that needs cleaning now and then.Is this the motor?. This is where the actual sunroof control switch attaches . I can only adjust the position when i push the switch in. I can move the sunroof to all positions.
I,ll strip it down and take a couple of snaps.
Sorry about the delay getting back, had to do 96 hours this last week so not had time to surf.....
Mark  :y
Brikhead
The confusion is probably my fault Mate!
I was trying to say that I do have a sunroof control unit that you have asked for but I don't want to separate it from the motor, also selling just the control unit would leave me unable to sell the 'kit' to Vectra owners...
tomoco
Understood mate.  :y.
just took mine apart and put it back together, plugged it in and it seems to work for now. Its gone back to having a mind of its own again :-/
i'll keep looking
Mark
QuoteThanks guys. I think im getting myself confused as to what part i need. I need the black plastic box. Its the one that contains the circuit board and the black disc that needs cleaning now and then.Is this the motor?. This is where the actual sunroof control switch attaches . ....
the motor & electrickery controls are all in one unit, I know you can split it up, but if you wanted a new one, you'd get the complete thing.  ;)
MutantCav
I assume the facelift one is the same as the mini facelift...I have one here you can have...I will send you the whole lot if you like or just the bits you need...pm sent
