Wanted: INFO DISPLAY
Started by Road Hog Mad, 23 March 2011, 19:31:25
Road Hog Mad
PM me with a price including P&P to UK, I think the info display I need is the old type it has two plugs at the back and three bulbs light it up.
My current one has a pixel problem and my mate can't read it.
Road Hog Mad
Yeah... I am the omega owners spaz for the night...  :'(
sjc
MutantCav
Will be pre mini facelift so before Sept 97...
sjc
In that case, I have one here.  Will power it up and check pixels are ok then work out postage cost.
Road Hog Mad
#5
It's an R Reg, I do believe its a 97.
In the Omega gallery I have posted some pics, or here's a direct link with some pics... http://img585.imageshack.us/slideshow/webplayer.php?id=image0039z.jpg
I'm outside of Manchester if you are local, could probably pick it up.
As said, the back of the info display takes a big plug and a small plug and has three bulbs in the back.
It doesn't say 'brakelight check' when you start the car up, it just lights up the bottom right 'check' light and goes off when you press the foot brake.
trying to recall the serial number / model no. on the back, 7777 something.....
MutantCav
Mini facelift came in about mid Sept 97 just at the beginning of the R reg...of course there will be some cars made before mini facelift registered after that...but basically the plug on the back of the MID changed from black and yellow to a single grey one for the mini facelift models...the black and yellow plugged MID's are generally the only ones that have the pixel problem...
Road Hog Mad
#7
that's the one, just need someone with a spare lol  :y
i wonder what differences there was between the mini facelift from the original?
the head restraints in this one have holes in them
Road Hog Mad
i'm still in need of one if anyone has one?
sjc
Ok, got the one off my car.  The numbers on the back are 7777-4994, GM 90379234.  It has 2 sockets on the back, a large 26 pin yellow one and a small 12 pin black one and 2 lights.
Does this sound like the one you're after?  You said yours has 3 lights, can you check?
Road Hog Mad
I'm still after the LCD display.
sjc
I presume then, that the one I've mentioned above is not what you're after?
Road Hog Mad
QuoteI presume then, that the one I've mentioned above is not what you're after?
Sorry, I must need new glasses, I will check as soon as I can.
sjc
;D  :y
Road Hog Mad
5 more days in work then 4 off, so will check when I am off unless one of my 5 days finish's early. I will post back here.
