WANTED: 3.2 DBW engine parts please
Started by SJKOO01, 30 April 2011, 17:15:33
SJKOO01
[size=14]
[/b][/size]
[size=12]I'm after passenger side coil pack in good condition with the spark boots in good condition
Air Plenum, including the bolts, rubber bungs and breathers
pair of camshaft covers
If you could let me know how much you want for each item and postal costs, I'd be greatful thanks.[/size]
See below  :y
GM  :y
Thought the cam covers were the same across the V6 range :-/
2.6 and 3.2 camcovers are the same as each other but different from 2.5 and 3.0 ones afaik. Im assuming the covers for cable/DBW are different from each other ?
I have camcovers,plenum with breathers and bolts (but no plastic caps) if your interested gooseman. Will have a think on price and drop you a pm. :y
Postage might sting a bit. Plenum is quite heavy. :(
You want the plenum without the throttle bodies attached, yes ?
Quote2.6 and 3.2 camcovers are the same as each other but different from 2.5 and 3.0 ones afaik. Im assuming the covers for cable/DBW are different from each other ?
How you gonna manage that then ;D ;D ;D :P
coming from someone from Birrisull. ::)
QuotePostage might sting a bit. Plenum is quite heavy. :(
You could always use a carrier service, maybe better than going down to the local post office.  DHL this way used to do a sort of, if you can get it in one of the smallist you can get away with pre-sized boxes, it was cheaper!
I'm in no immediate rush for the parts, but if you want to get a few quotes first I'm okay with that thanks. :y
Will investigate couriers mate. Jamesv6 suggested one recently, who I will look into. :y
SJKOO01
Quotesomeone with sharper elbows ? ::) :D
;D ;D
Someone who may know a story to put on here if I hadn't from them  ;D
Cheers anyhow Albs  :)
SJKOO01
Thanks to those that PM'd / replied.
I'm still after a passenger side coil pack in good condition with the spark boots in good condition.
Now sorted out with; Air Plenum, camshaft covers. thanks
